OK TBI gurus I got another one for ya.
Discussion in 'The Garage' started by zcarczar, Jul 17, 2003.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Ok I'm stumped right now, my holley TBI went out so I got a used throttle body for a really good deal and I put that one instead of fixing the holley. Well ever since I put the new TBI on I have been having a problem with a surging idle and lack of throttle response up until about 50% throttle or I am over 20 mph. The truck also appears to be running lean according to the scanner.
    So far I have rebuilt the Fuel Pressure regulator, replaced the MAP sensor and Fuel Pump. Fuel filter is less than a month old.
    You can also watch the injectors while the idle is surging and when it hits the lowest point of the surge the injector cone starts breaking up.
    Im at a loss on what to do, I have checked fuel pressure and everything is good there. Anybody have any ideas? /forums/images/graemlins/1zhelp.gif
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Did ya check the TPS???????
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,259
    72
    Humboldt/Pacifica, CA
    Sounds like the injectors are clogged. Have you tried adding some fuel injector cleaner in the gas tank to clean them out? People on here recommend "Top Engine Cleaner" (p/n: 1050002 ) from the dealer.
  4. La Barge
    La Barge Registered Member
    Jan 22, 2003
    68
    Gilbert , AZ
    dido
  5. BigJohnson
    BigJohnson 1/2 ton status
    Jan 22, 2001
    207
    AL
    Check the idle air controller motor. If it is plugged up with carbon it can cause eratic idle. You can clean them with carb cleaner and a brush or get a new one there not that expensive.
  6. zcarczar
    Feb 10, 2002
    2,495
    TPS is cool, voltage stays the same even when surging.
    Im leaning towards injectors too, Is it OK for me to run the top engine cleaner through the gas tank?
  7. rampage
    Mar 20, 2001
    2,259
    72
    Don't know, never used it. I'm guessing that it works like all the rest, just pour it in when you fill up. Pick it up at the dealer and let me know how much $$ and how well it works for you. /forums/images/graemlins/deal.gif
  8. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    what was wrong with your holley ?
  9. zcarczar
    Feb 10, 2002
    2,495
    Well, I was told not to run top engine cleaner through the gas tank because its really hard on the fuel pump. So instead I was told to run some Techron through the tank, I have about 1/2 a tank left before the tank full of techron is empty.
    After wheelin all weekend I have noticed that the truck is running a tad bit better and the idle isnt surging near as bad as before.
    The holley unit is a bad design for a stock engine, it ran rich even when i backed the fuel pressure off and it finally gave out on me when the injectors stuck open.
  10. K5Dan
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    i hope you get it all straightened out /forums/images/graemlins/smile.gif
  11. MousePowrd
    MousePowrd 1/2 ton status
    May 7, 2003
    215
    Saginaw, MI
    vacuum leak
    vacuum leak
    vacuum leak
    Check the TB gasket and all of you lines first, then look at the intake manifold.
    That is why the computer reads lean.
