Ok the 85 K5 is finally at the house, power windows and locks problem.
Discussion in 'The Garage' started by SF87K5, Aug 17, 2003.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Finally got the 85 K5 I told you all about and its here at the house. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Ok got a couple of questions for you guys.
    1. The pwoer rear window goes up slow and the key switch for it does not work. Do I need to get a new motor and key switch for it, and if so how hard is it to swap out of the tail gate.
    2. The power windows go up and down very slowly also. Do I need new switches of motors for them also.
    3. The power locks will not unlock or lock. When you hit the switch you can hear them tring to lock and unlock. Is that the switch or the motor for those also?
    I am thinking about changing all the switches and motors but want to try to save as much as I can so input is needed on these same problems I have.
    Thanks everyone thats on this site. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Ok the 85 K5 is finally at the house/
    hey danny, glad to hear you finally got it home..whats the wifeys verdict on the one tons? shh...
    ok here goes..try putting some dielectric grease in the connectors for all the switched and the connectors for the motors..see if that helps, also, get some window run lube or maybe use the dielectric grease to lube where the windows run.. /forums/images/graemlins/thumb.gif
  3. SF87K5
    Oct 27, 2002
    1,105
    Josh still asking LOL.
    Cool thanks for the idea. I will stop at auto zone on the way home tomorrow and pick some up. /forums/images/graemlins/thumb.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    not a problem danny...you busy? chat? im bored..
  5. SF87K5
    Oct 27, 2002
    1,105
    Well I just got done working on my locks and windows. I found out the my tail gate is bent about 1" out on the pass side. So thats why the window will not go all the way up without help. The key switch on the tail gate is gone also, so I need to buy a new switch for that.
    I think the power lock relay is going out because it just "clicks" when I hit the power lock button. Can this happen and do I just need to get a new relay or is there more to it than that?
    The driver side window works fine now but the pass side is still very tempermental. It does not always want to go all the way down or up using the driver's button or the pass button. Could the motor be going out on that side also?
    Thanks for everyone's help on this board. I think this is the best board on the net. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif Thank you Steve for making this site.
  6. Confedneck
    Nov 1, 2002
    5,236
    it could be the motor or the switch, try cleaning the contacts in the switch to see what happens..if you knock on the door when working the switch (near where the motor rests), will the window continute down?
  7. SF87K5
    Oct 27, 2002
    1,105
    yes it will still go down when you hit on the door and lower the window.
  8. Confedneck
    Nov 1, 2002
    5,236
    i meant when it stops partway down, if you knock on the door, will it go the rest of the way? if so it needs a motor..
  9. SF87K5
    Oct 27, 2002
    1,105
    yeah it does. Crap that is going to be a pain to change that out. /forums/images/graemlins/frown.gif
  10. Confedneck
    Nov 1, 2002
    5,236
    tell ya what...ill change the window motor for you, send me the door...LOL
  11. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    Are you sure you have good power? Seems too coincidental that every thing seems to run slugish. Low batter charge? bad connections etc???
    Just a thought /forums/images/graemlins/wink.gif
  12. SF87K5
    Oct 27, 2002
    1,105
    Well my battery gauge in the truck does not work, I need to fix it tomorrow. But the alternator charges good and the battery holds a good charge.
    I will look to see if the wires for the gauge are conected or not.
