OK, This may be astupid question...but...
Discussion in 'OffRoad Design' started by BlazerWheels, Dec 5, 2003.
  1. BlazerWheels
    BlazerWheels 1/2 ton status
    Feb 13, 2003
    587
    California
    Would putting zero rates on all four corners, be a good cost effective way at getting a little bit of lift (I know 1") at an inexpensive price??? Eventually I want to add 2.5" or 3" spring lift (then I would total 3.5 or 4), but for now I have very little $$$$ and need to WEEN my wife into the idea anyway...So what do you think?? /forums/images/graemlins/confused.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, you can do that /forums/images/graemlins/thumb.gif
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    i have zero rates on all 4 corners. handy way to get a lil extra lift without stiffer spring packs. They let you easily relocate axles as well. /forums/images/graemlins/thumb.gif
    j
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's either the zero rates or a 1" body lift. I prefer the body lift, it makes everything under the truck easier to work on if nothing else. I now have one on everything I own.
  5. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    I'll second that. It's a LOT easier to get around things. I was having a bad plug wire issue for a while, but it was a piece of cake to get to them, they were right through the wheel well /forums/images/graemlins/grin.gif
    For the hassle of either tearing apart my spring packs or lifting the body a little, I'd lift the body. Combined with a new set of body bushings and you'll be golden.
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    "Tearing apart" the spring packs really isn't that hard. Use C-clamps to hold them together, take old pins out, put new pins in and bolt add-a-leaves on. Easy. Took me about 10 minutes per spring, but I wasn't exactly sure what I was doing...
  7. Kyle89K5
    2,273
    OKLAHOMA
    That part is easy, the part that gets me is the U-bolts and getting the old pin out. Never fails, my old pin will have to be ground or cut out. I've gotten faster, I just cut the u bolts off now. Don't even bother trying to take them off.
