ok to heat cailper bolts?
Discussion in 'The Garage' started by bryguy00b, Nov 28, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    of course the caliper bolts are rusted in there good like i knew they would be on the s-10.. dont have any penatrating oil or any chit like that at the moment, but i do got a torch /forums/images/graemlins/grin.gif..is it ok to heat them or no?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Don't heat the bolt, heat the backing plate they're seized into. /forums/images/graemlins/thumb.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    backing plate? im not sure what ur talking about, not the back brakes the front.....you mean heat the caliper or something..
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Heat makes metal expand. If you heat the bolt it won't do any good.
    Don't heat the bolt. Heat what the bolts threads into to get the bolt out.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    heat the backing plate....the front calipers are bolted TO the backing plate /forums/images/graemlins/rolleyes.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ohhh ur talkin bout the steering knuckle, right!!?? i wasnt sure what u ment, when u said backing plate i was thinking of a backing plate on drum brakes..
  7. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I would try something other than heat. Brake fluid is VERY flammable, and I dont think you want to replace the caliper because you over heated it and ruined the seal.
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ud have to do some pretty good heating to get damage the seal...but i would be heating the knuckle that the bolt goes through..
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i would not heat, i would get penetrating oil
    the threads are at the headsof the bolts so thats where you would need to heat at, and the bolts have rubber guide seal things that you will burn up and ruin, they sit in the bolt ears of the calipers.
    when you put bolts back in, use plumbers pipe thread dope on a brush, they will never freeze again /forums/images/graemlins/laugh.gif i use this stuff on head bolts and other threads that i dont want to seize or leak coolant through like head bolts, etc.
  10. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Its not the knuckle. It's the backing plate, also known as the caliper support.
    The threads are on the caliper support, you'll be able to see them from the backside, just under the head of the bolt.
    Is the allen bolt head stripped or something?
    You'd want to heat it slightly around the bolt, directly onto the backing plate. The concept of the metal expanding and opening up the hole slightly isn't what is going to help. That actually makes the hole smaller as the metal around the hole expands. The heat is what affects the rust/siezed portion of the threads and breaks it free.
  11. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    Don't you have a breaker bar? What I do is use a 1/2" ratchet with an allen head socket, slip a piece of pipe over the ratchet and use that leverage. I can break most any bolt loose that way.
  12. Waxer
    1,857
    Long Beach, CA.
    He can do that, in conjunction with hitting the caliper support with a hammer, right where the bolt goes through. The sheer force of the hammering along with the pressure from trying to turn the bolt will break it free.
    Thats exactly how I got my D60 king pins off.
    This method will negate the need for heat, and prevent any problems from overheating the area. Not to mention, its a hell of a lot safer /forums/images/graemlins/smile.gif
  13. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    durr *brain fart*..never thought of that..lol but hey it was midnight and i was tired..
    hmmm didnt even know they called that the backing plate..new to me.. /forums/images/graemlins/shocked.gif but in any event..guess ill stay away from heating it
