ok to mount recovery hook here?
Discussion in 'The Garage' started by BranndonC, Dec 9, 2003.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    if i put a piece of 1/2 inch plate above it and bolt it in?
  2. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    when you say above it do you mean use the plate as a washer above the frame? or use the plate as a spacer?
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yup /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    above the frame, kinda as a strengthener/washer
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    it would be OK, but I would advise against it.
    I've seen those thing sheer off and shoot out like a bullet. IMHO, a "true" off road bumper is in order in the front. I don't want to be hanging for my life on a strap thinking "I hope that hook holds!"
    JM2C
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks zakk, i plan on the 4x4iron hybrid bumper or something comparible. but untill then, i want some hooks on the front and that was the most logical place i found to mount it.
  7. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    That's what I did, one on each frame horn. I ended up putting a 1/4" plate on each side of the frame instead of just using one 1/2" plate, made it a ton stronger. I am not afraid of it ripping out because I have pulled some heavy sh!t with it, straps and cables break before the hooks go. /forums/images/graemlins/truck.gif
  8. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    i dont think it'll be a problem. a beefy bumper that is attached to the frame in more than 2 spots is always the best way to go, but until you have ur kick azz bumper etc, the hooks/horns approach oughta work for ya.
    j
  9. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    make sure you have at least grade 8 or higher bolts
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Aren't those hooks only rated at 10,000 pounds? I'd be concerned about that thing snapping and becoming a projectile. /forums/images/graemlins/eek.gif The factory hooks are considerably beefier. /forums/images/graemlins/cool.gif
  11. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Also, make sure you have a fat wallett and a good lawyer. Cause you may be getting booked for manslaughter.
  12. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/rolleyes.gif
    please list all the legal cases that involve injury claims related to these particular types of hooks.
    yeah, thats what a i thought.
    j
  13. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    so 10k isnt enough? it is mainly sand dunes and hills i'd be doing, no mud
  14. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    One thing is correct - this type of tow hook should be mounted where the bolts are in line with the towing plane. Meaning, just as you have it. Be sure to plate the frame as you mentioned.
    I ripped my factory tow hook out of the frame, with only a thread holding on. Luckily my truck was freed on the very pull that broke the tow hook mounts.
    GM dropped the ball on the factory tow hook mounting, expecially with the 81 up K5's. They had the "S shaped" tow hook mounting where my 78 had the straight through mounting. But, the way the factory mounted my tow hooks, was straight up and down. Meaning, the bottom bolt ripped through the frame, leaving only the top bolt and torn frame intact. /forums/images/graemlins/blush.gif
  15. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    j
    Not talking about the quality of the hooks. I am talking about the method of installation of said hooks. So STFU. /forums/images/graemlins/rolleyes.gif
  16. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    j
    HIGHLY NOT RECOMENDED!
    but, the previos owner of my truck had those type hooks installed with just one bolt on the frame and not plating /forums/images/graemlins/eek.gif
    i watched him do a good 10 or 15 5-10' slack jerks in the mud and they didn't pop out. i only watched him wheel once and he had that truck over a year, so i don't think with 2 bolts you'll be in bad shape at all. mine are mounted with 2 bolts to the frame now, no plate, but not that ya'll mention it i think i'll plate it up before i wheel her again.
  17. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    dont see anything out of the ordinary about his choice of installation location or method of attachment. Lawsuits are always a concern, but honestly, most of our hardcore wheelers run bumpers they bent/welded up themselves which (no matter how beefy) if they fail and someone is injured there is a MUCH better chance of a lawsuit (unless you're a certified welder and have an engineering degree).
    in any case, the guy is buying something billed as a tow hook and is attaching it to the frame of his vehicle... if flat out murderers can lay the blame on gun manufacturers, SURELY a person brought to court where a tow hook was to blame he could pin it on the company that produced them. this is prolly why we don't see lawsuits like you're talking about much, if at all. Still waiting to see some evidence of such a thing...
    j
    ps: i guess you missed the day in 7th grade English class where they tell you that resorting to insults = admitting defeat in an argument. /forums/images/graemlins/rolleyes.gif
  18. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    j
    Where was the insult?
  19. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    the way you and i and most other folks with heavy, powerful trucks unstick people is to slowly get all the slack out of the rope then gently pull them out of there holes. i have never, ever done a "jerk" type recovery because i have never needed to. i think that hook will be fine right where you have it. but thats just me. if you had to pull me out with that hook, i would feel safe
  20. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i might even be able to weld in the 1/4 inch plate also /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
