OK to run w/o rear driveshaft, 203?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Mar 24, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Will it cause any damage to the 203 case to run without a rear drive shaft?
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Obviously this is a temp fix I guess...cause you do know that you can't go anywhere with a 203 case and missing a driveshaft unless you're in Low Loc right? That means your top speed is maybe 25 mph...You weren't planning on driving it on the street were ya? /forums/images/graemlins/grin.gif
  3. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Why couldnt you use high lock? as long as its locked their shouldnt be a difference. Now i could be mistaken thats why im asking!!
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I ran for a month in High Lock without a front driveshaft (I've got a NP-203) Went down the interstate at 80 MPH just fine.
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    high loc will work too- i did it, but i broke my u-joint. i also might add my transfer case grinds real bad sometimes and when i ran it like this it grinded worse than ever.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    without a front and without a rear are different. without a front you won't need it in loc. well, i don't anyway. without a rear you'll need loc though. power is always distributed to the rear wheels, but not the front.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My 203 is still fulltime, so yes, it needed to be in lock.
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    so is mine, and when i unlock my hubs i leave it in 4wheel high (no loc) and it drives. . . hmm, mine is probably screwed up my truck is a piece.
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Just has to be locked in. I am running in High lock right now w/out my front driveshaft. I would not recommend running it that way w/out a rear driveshaft...unless I needed to move it from one side of the drive way tot he other!
  10. laketex
    6,220
    North Texas
    ok, i'm assclown of the month...sorry guys. For some reason, i was kinda outta it this mornin...
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Actually, you do with a 203 that has not been converted to part time.
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] My 203 is factory fulltime with the factory front axle. No hubs to lock or unlock. If you have lockputs up front, are you sure it not parttime ???
  13. jwingfield2k
    jwingfield2k Registered Member
    Jan 29, 2003
    29
    Richardson, Texas
    Plus you know running the front axle with drive shaft power and turning at the same time is gonna eat the shite outta the tires.
  14. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    someone before me put the hubs on there to save mileage, why would the convert it AND put on hubs? that doesn't make sense. yes, i'm sure, it stillh as four working positions. but it's a crappy case, maybe a pin is broken, because i promise it drive in 4 wheel high with unlocked front hubs.
  15. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    You can run on just the front while in loc (high or low), but take it easy. The front shaft (especially if already worn), was not meant to take the abuse the rear one does. I've seen guys toast the front shaft in short order, when running without the rear shaft in place. You can do it, just take it easy.
  16. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Nah, just take it easy. When I blew the spider gears on my rear 10 bolt I ran the NP208 on the expressway at 60mph for 110 miles and then another 30 miles on the highway. Steering isn't fun nor is slowing down fun like that but it works.
    You'll kill the front shaft and wheel universals if you accelerate hard or accelerate too much around a corner.
