ok why isnt this thing starting!?
Discussion in 'The Garage' started by bryguy00b, Feb 16, 2004.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok i got it getting spark now..changed the modual yet again and now it trys to start so its getting spark..just put a "new carb" on it..holley 600...its getting fuel up to the carb as i can see it goin through the clear filter...but it will crank and sputter..like try to start but just wont do it...only if i pour gas down the carb it will fire up for a second then quit, did this with the other carb too..what u think could be the problem? i checked the wires there all in right..
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Can you see it spray through the jets when you manually open the throttle blades?
  3. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Fuel pump...kink in a hose...
    I had the same problem with my Q-Jet..I could see the fuel go in but when it would try to start it would run out of fuel because of the kink in the hose right down my the fuel pump....
    Just food for thought.. /forums/images/graemlins/dunno.gif
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Yea I was gonna say fuel pressure. Sounds to me all it wants is more gas. Good luck to ya.
    Allan
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Bad air leak? Check your manifold for tightness and all your vacuum lines and blanking plugs. /forums/images/graemlins/confused.gif
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea fuel pump was what i was thinking to..only thing i can think of..vacuum..i think everything is good there...ill stick the gauge in the line today and see what happens..all let yall know..thanx! /forums/images/graemlins/peace.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Did you remove the distributor while working on it? If so, then it's possible that the distributor got put back in incorrectly. If it's off by a few teeth then the spark will be happening at the wrong times.
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea...and no i didnt take it out, just everything in it..(but for the pickup coil of course) so i dunno...im ganna but a guage in the line and see what the presure is like i guess..
