ok WTF !!!!
Discussion in 'The Garage' started by onlychevy6, Feb 2, 2007.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    I have destroyed 2 speedo cables in the last month. Both cables from different part stores. one from Napa and the other Kragen. Where can you find the piece that the speedo cable connects to on the np205 transfer case? Yes it is mechanical. That is where the cable is shredding? Or does anyone have any other suggestions. Not to mention it is off by 10 mph on the gauge. Says i am going 60 when it should say 70 mph?
  2. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Did you have a new speedo gear cut when you went to bigger tires? Was it calibrated when you had 35's? That's why it's reading slower.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Get a cheap GPS
  4. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    No i did not have anything done to it. All we did when it was at Mikes was put everything in and go. So it has never been calibrated. I know that needs to be done but don't remember how.:confused:
  5. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Did you install the cable lube when you put the new cable in? There is a lube called cable eaze that you put into the cable housing so that the cable doesn't bind and twist up and break.
  7. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    if the cables are too short, or routed in such a way that they must make tight corners, they'll bind inside the sheath and break.
  8. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    I would have to say yes. Each time i bought a cable it came with some red looking lube.
  9. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    The cables are 84" long so i know there is plenty length. Only thing i can think f is my exhaust is heating it up and causing this to shred. but it is only doing do at the transfer case screw in thing. Not about 6" back or so where the exhaust runs.(I am running dual exhaust)
  10. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    if i read that correctly that is for 2wd tranny's i have the 4wd th350. And if i remember correctly when the tranny was re-built i believe we told them i was running 4.10 gears? I will have to ask.
  11. Arizcowboy
    Arizcowboy Registered Member
    Feb 1, 2007
    5
    Mesa, Arizona
    Cool. I am new to K5 forums and I can tell already there is going to be lots of useful information on here for me to learn from! I just happen to have a broken speedo cable. The cable is broken right where it goes into my NP205 case. I havent bothered to fix it yet, as I prefer to use an onboard GPS anyways! :) But I guess I could get under there and fix it just to see how far it is off!
    Arizcowboy
  12. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    There is a section talking about the difference between gear sizes on 2wd chevys and 2wd Pontiacs, buicks, olds. That's what I thin you say. I don't think 2wd or 4wd makes a difference, as the calculator is only asking for the number of teeth.
  13. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,228
    485
    New Hampshire
    I got my speedo cable from LMC and its pretty good quality. And it fits nicely
