OKAY, enough with the joining stuff, i have a k5 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jul 31, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    in the past 6 months have replaced near all the front end parts
    tie rods and ends
    steering stabilizer
    shocks
    sway bar bushings
    front end alignment
    new wheels and tires
    and the truck now seems a little squirely, and i noticed the steering shaft under the hood had play at the columning connection, so i replaced bearing and outer bushing only to find they were perfectly fine, and the guys who did my alignment left the nut off the steering wheel and the shaft had slipped down. figured this out when the steering got funny and the blinker shutoff started acting funny at the same time. now to the question
    what should i look for as a cause of this sloppiness??
    when driving about 15-20 i make some small turns left to right and the truck just feels "weird"
    and don't anyone one tell me to not make small left to right turns. LOL
    guy say to doc, "it hurts when I...." doc says "well then don't..."
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Are you sure the frame is not cracked around the steering box????????
    If it ain't broke.......Don't fix it....
  3. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Are the new tires bigger than the old tires?
    Keep it simple!
  4. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    positive about frame, put the wheel against the curb and got ny buddy to turn wheel as i check and no movement at the gear box or frame, and the tires are the same size, besides this started a little while after the tires not immediately if that makes a difference?
    what's in it now?
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If you have radials. Move the left one to the right one and see if that helps. It is called radial were. The first tires on my Blazer were those. I switched tires and the problem went away.........Dan
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    There could be some play in your ball joints that's affecting your toe-in.............turning the wheel puts stress on the ball joints and any play will result in wandering and constant misalignment.
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  7. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    even with new tires???
    and i also repalcesd the ball joints. how to check if the new ones could be bad besides just trying to wiggle???
    what's in it now?
  8. Can Can
    15,552
    136
    Jack up the truck and pull back and forth on the top and bottom of the tire. The movement may be subtle so it's best to get someone to help you. Watch for any play in the ball joints- as far as I know, any play is bad..............
    Your problem could also be bad wheel bearings, too.
  9. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Yes just swap the the two front tires.....Dan
  10. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    What about packing the wheel bearings!
    Keep it simple!
  11. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    i am getting a strange growling sound when i slow down in a curve, like when exiting the freeway. I had forgotten about that, until you said wheel bearings.
    you guys do not talk about anything cool until tommorrrow, it is way late on the east coast and i have to go to bed before colorado K5 is listed in a divorce.
    I will jack the truck up in the AM and wiggle and swap, then i will even see if i can locate my front end problem, LOL
    thanks
    later
    what's in it now?
  12. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    i say frame is cracked im doing mine right know and theres only one crack you can see all the other i couldnt find tell i wire wheeled the whole thing for like a hour and i had hardly any movement around box but i kept hearing a poping noise
    jsut my 2 cents
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  13. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    i'm thinking wheel bearings, especially because of the growling noise. Jack the front end up and start wiggeling stuff, spin stuff, basically move everything that should move, and try to move stuff that shouldn't.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  14. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I would say to first check the wheel bearings, and also check to see if your drag link is worn.
    I've got a mind like a . . . a . . . what's that thing called?
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
  15. dyeager535
    26,977
    Well, if you have no movement at the gearbox, but do at the wheel, as you say, then you've got a stereing shaft/column problem. Did you look at the top of the steering box, to see if the input shaft (column to steering wheel connection) is actually moving without the wheels moving, or is the "intermediate shaft" (piece that connects the steering box to column) damaged? That rubber/fiber connector could be shot as well.
    But if the pitman arm isn't moving when the steering wheel is, obviously its nothing in the suspension/steering components, EXCEPT everything "before" the pitman arm.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
