okay, I need help with a transfer case!
Discussion in 'The Garage' started by OrangeCrushK10, Oct 6, 2004.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    My wife (PlumCrazyJimmy) just bought a '79 Jimmy, but the np203 transfer case is going bad. She wants to have a np205 like mine, but I need to know which years I can use. Does anybody know how many splines her np203 has? And what years of np205 has the same?
    Any help would be great, thanks guys! /forums/images/graemlins/thumb.gif
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    If the 203 is behind a th350 its 27 spline (this is most likely). Any NP205 that came from behind a TH350 would work. Its a direct bolt in swap-minus drive shaft lengths, if you get the adaptor, sleeve, and shifter with the NP205.
  3. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    The spline count is 27 as her Jimmy should have a TH350 tranny. Any 205 from a TH350 will fit regardless of its year. The Th350/205 combo's started somewhere around 71 and ran until 80 (last year for the 205 in a 1/2 ton).
    Be sure to get the adapater and shifter with the 205 as these are different from the 203.
    Note, 205's from other tranny applications (especially one from a 4spd) can be modified to fit your TH350 fairly easy if you have trouble finding one.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Man I type slow. /forums/images/graemlins/doah.gif /forums/images/graemlins/thumb.gif
  5. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Are you mocking me? /forums/images/graemlins/histerical.gif
