Ol' Saggy...
Discussion in 'The Garage' started by Lowtode, Feb 27, 2004.
  1. Lowtode
    Lowtode Registered Member
    Dec 23, 2002
    14
    Norman, OK
    Ol\' Saggy...
    Hope this isn't perceived as being pompous, but I had a question.
    I put a 4” tuff country lift on my 72 Blazer and it seems to sag in the back quite a bit (maybe 2” compared to the front). I got the blocks v. the springs, since I just got new stock springs from LMC. My question is, if I got new 4” springs in the rear would that help level it our or should I go with some 5.5” or 6” springs.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Re: 4\" Question
    You can do a shackle flip and keep the springs, maybe a small block to adjust it if it comes out too low
  3. Lowtode
    Dec 23, 2002
    14
    Norman, OK
    Re: 4\" Question
    Are they normally saggy in the back? I've seen some that are, but I'd prefer it to be level.
  4. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Re: 4\" Question
    It varies truck to truck with use but it seems to be a problem for a few people
    Level is great, the only other way is higher in the rear and I belive thats only good for towing as tounge wieght weighs down the rear... or something.... /forums/images/graemlins/tongue.gif
