old 72 style roch Q jet power piston spring ?
Discussion in 'The Garage' started by R72K5, May 23, 2005.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    is there supposed to be a spring standing up under the power piston assembly on the 1972 chevy Q jets or did not all of them get a spring ?
    7042206 is the carb stamping
    thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well i looked at a diagram and saw one so i dug through my Q jet parts stash and found one of the springs and put it under the PP asembly and the damn new accelerator pump was not squirting so i robbed an old beater one from a 78 Q jet and its good to go squirts and runs top notch excellent now
    yay!
    the PP assembly in the 72 and 78 carb are the short body style BTW, dont have the threaded in brass deal with stem with two flat sides on it in there
    something called EPT setting or something that the later oens have ? i forget what its called, the older 708 and older series Qjets dont have this thing apparently
    thanks
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its an APT on later carbs , adjustable part throttle . Its basically your primaries fuel mixture control .
    On my basically stock 305 with one of those , 1 turn out passes emissions , 2 3/4 turns out is best balance of power and mileage , and 4 turns it runs rich but like a scalded cat :D
    Edelbrocks with one come 2 turns out from factory I believe .
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    good info pauly, appreciated :D
    APt is what i was trying ot remembe,r yep!
    lol
    :thumb:
