Old 'pilot bushing' removal
Discussion in 'The Garage' started by BowtieRed, Sep 6, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Old \'pilot bushing\' removal
    I need to put in my manual transmission pilot bushing but the old bushing in the crashaft won't come out. the grease idea with the socket doesn't work, the grease won't stay in/ don't have socket/ bar right size. can't find a slide hammer with the right attachment, any other ideas?
    HELP!
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Re: Old \'pilot bushing\' removal
    ok- i'm an asstarded somanabastard. . . i took my pilot tool and it fit perfectly in the old bushing, so can i just use that one? the fit was the same as the new bushing.
  3. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    Only use it if you cannot get the old pilot bushing out. If there is an Autozone by you, they lend tools out for free. If you lived closer I could lend you the tool to do the job. /forums/images/graemlins/tongue.gif
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i went to autozone, but they don't have the attachment.
    i do not $80 for the deposit on the slide hammer.
  5. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I had this same problem a few years back. Used a big ole tap that threaded the inside of the bearing. Then used the same size bolt to "self extract" the bearing from the crank. /forums/images/graemlins/wink.gif
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That's what I do, but you dont even need to use a bolt. Just keep turning the tap after it bottoms out in the crankshaft, and the bushing will pop right out.
