Old power tools ?????
Discussion in 'The Lounge' started by jarheadk5, May 22, 2004.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Anyone know much about old power tools? Specifically, an older Craftsman radial arm saw. It used to work well, but now the motor won't start or run. It's a capacitor-start motor, and there IS power coming into the J-box where the capacitor is. I suspect that the cap is dead. Is there an easy way to check this theory, or should I just try to track down the appropriate cap, replace it, and see what happens?
  2. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    If its not the cap, most likely its the brushes. If you plug it in the cap should charge, but only to a set # of microfarads. If you short the out leg to ground in the dark it should spark. I would check the brushes 1st though. This assumes eveything else is good.
  3. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Is there a way to check the cap with a multimeter?
    I'm looking at the parts breakdown in the manual for the saw, and I don't see brushes listed as a part. EVERYTHING else is listed, down to wire nuts in the J-box, but no brushes. Could this be a brushless motor???
  4. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Anyone?? /forums/images/graemlins/confused.gif
  5. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Being old I doubt it. The brushes are just bolcks of carbon. Nothing to check, when they wear out they are gone.
  6. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Hey I forgot to mention unplug the saw before you short the cap. I assumed you would know that, but just in case..
  7. jarheadk5
    Mar 6, 2000
    4,389
    PA
    I hear ya there. I plugged and unplugged that saw so many times while shooting the wiring that a couple times, when I thought I had found a dead wire, it was really that I hadn't plugged it back in... /forums/images/graemlins/doah.gif
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Did you make any progress? (& BTTT, maybe someone can help)
  9. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Nah, other stuff got in the way. Going on a brief vacation this coming week, then I'll be back to it the week after. Thanks for the help, BTW.
  10. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Hell if it is a Craftsman just take it back to Sears and exchange it. Remember Craftsman have a life time warranty. /forums/images/graemlins/thumb.gif
  11. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Only hand tools, not power tools. Especially not power tools that are, quite possibly, older than the owner. /forums/images/graemlins/doah.gif
