old radio in a 87k5
Discussion in 'Audio' started by bamf, Jan 28, 2006.
  1. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    Fayetteville North carolina
    Trying to take out my old radio in my k5? now the question is how?
    lol took off dash and dash bazel? but cant figure out what else to take off now.
    please help.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Is it the factory style radio that has to have the radio come out thru the backside and under the dash? Also, check on the backside of the radio to see if there is any strapping to help support the back end of the radio. On the front side, there are usually nuts holding the radio to the steel dash structure on the 2 turn dial knob shafts.
  3. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    yes its the factory radio. I un bolted the support bracket. But now how the hell does it come out? Do i have to take the air ducts out? under the metal frame?
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If the air ducts are in your way of getting the radio out, then yeah. Unless you can move/twist/whatever the duct out of the way enough to get it out. But you have to take it out thru the back, then out from underneigh.
  5. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    thats some bull**** lol oh well ill firgure it out sometime today
  6. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    woot got that SOB out. now this guy that had the blazer before me had a after market radio in it but he never took out the old radio. and he took the after market radio with him. so now im trying to figure out where the hell all of these wires goto. i have a **** load. Lets see so far i have found a rocker switch, 3 toggles, and a few other lose end wires that ran together from the group of wires that he had connected together. WISH ME luck
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If the wireing is a mess, I highly recomend capping them all off and run new wires. It's not hard, and takes the worries of a wire fire out of the equation.
  8. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    the wiring is pretty bad just got back from cleaning house. I only cut wires out that I knew where with the stero. I did find the factory harness and i left that crap alone. dont know if its any good since I dont have any speakers. hell i dont even have a radio. I do have a nefty place to install it once i get it.
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
  10. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I ran into something like this when I bought my '85. The PO hadn't really done anything good or bad (or anything at all except own it for 4 months) to the truck, but the guy that owned it before him was a real "Harry Half-ass" when it came to wiring.
    The wiring under the hood was functional, but haphazardly arranged. Oil pressure sending unit wire pinched under the head of a bellhousing bolt, things like that.
    Anyway, to the stereo wiring. There had been a generic DIN head unit in the thing when the PO bought it, but he said that the stereo wiring was so FUBARed that he gave up and just used a boombox (he barely drove it anyway). I got under the dash and FUBARed was an understatement. Those inexpensive plug adapters you can buy, so that you don't have to cut the factory wiring, were unknown to the guy that messed all this up, so he cut the factory plugs off and put various colored wires on the freshly cut leads.
    I really hate half-assed projects that would have been better if they'd never been started. If they couldn't afford to to it right, they should have just left it alone (like the last owner wisely did) until they had the money.
    I'm not even going to mess with that electrical disaster. I'm replacing the cracked dash pad anyway, so I'll just put in a new pair of 3-1/2 speakers and run new wiring from those to the head unit area at that time, as well as new power and ground leads. I'll find the ignition and illumination leads, and use the ignition lead to just pick a power relay for the stereo hot lead.
    I'll be running a thicker hot lead to the powered sub anyway; nothing special, probably a Kenwood KSC-SW1 for it's nice, small size. I'll worry about doing something with rear speakers later.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    With a nightmare like that, I'd cap off each wire (For fire prevention safty) and start from scratch and run all new wires.
