Old U-joint question
Discussion in 'The Garage' started by rotten03, Apr 16, 2004.
  1. rotten03
    rotten03 Registered Member
    Nov 11, 2003
    23
    Carterville, IL
    I know this has been beat to death but I cant find the answer. What Ujoint do I need to mate my 1/2 ton truck to a 14bff axle. The driveshaft that is. And do i need a special U-joint for the front D44 I just put on the front?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Napa PN 447 is a 1330-1350 - for a 10 bolt to 14 bolt
    Napa PN 348 is a 1310-1350 - 12 to 14 bolts
    I believe the 44 will bolt right up...not sure though...
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What he said, and yes, the D44 doesn't need a conversion joint, just bolts right up.
  4. rotten03
    Nov 11, 2003
    23
    Carterville, IL
    Thanks alot fellas.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Napa (Precision) PN 447 is a Saginaw S44-1350 - for a 10 bolt to 14 bolt Neapco part number 3-3140
    Napa (Precision) PN 348 is a 1310-1350 - 12 to 14 bolts Neapco part number 2-1153
    Fixed it for you.
    A 10 bolt does not use a 1330 or a Spicer style u joint at all. It uses a saginaw joint and that is why it has internal locking clips for retention.
    The 12 bolt rear axle uses 1310 u joints which have external locking clips in the driveshaft and locating tabs on the pinion yoke to keep the joint from walking side to side.
    All Chevy front axles reguardless of year or model have Spicer 1310 series U joints at the pinion including the Dana 60. This will be neapco part number 1-0153 but whatever is in your driveshaft currently will fit.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    14 bolt SF use spicer i know, just so anyone who needs to know does know, i know the 83 K20 rear shaft are spicer anyways, would be same deal for at least '81-87 years
    at napa to get one of these conversion joints you just need to tell them application of the axle and of the driveshaft and they will get the joint you need
    also the car 8.5" 10 bolts used outside lcips through the 70s i know
    just got done with a 74 8.5" nova axle and it was outside clips
    trucks opposite way aorund with the 8.5:"
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All 3/4 and 1 ton trucks use Spicer 1350 series u joints in the rear driveshaft.
    I was not referring to 10 bolts from cars or from the '70s. GM did not put a 10 bolt in the rear of their trucks at that time, and when they did, they all used Saginaw u joints with a few minor exceptions (4 speed trucks supposedly).
