Older style Ford shock towers
Discussion in 'Parts & Trucks Wanted' started by mrk5, Mar 27, 2007.
  1. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Looking for a set of the older style Ford shock towers, on the cheap I hope.
  2. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    I just gave away the older style to NateInChandler a couple weeks ago... Why don't you use the newer SD style? They're soo much easier to put in... Got them for $47 from Ford.
  3. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I think I have some brand new ones in my garage, let me check.
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    Sorry I can't help you.
  5. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    The way I'm going to install them, the new style won't work. Otherwise I would use the new version. As it is, I'm going to add some reinforcement to the older ones.
  6. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Let me know!
  7. badger red
    badger red 1/2 ton status
    Jul 30, 2004
    208
    south central KS
    Which are the older version--the cast or the stamped steel?
    Jeff
  8. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    This style:
  9. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    Sounds good, man. Let us know how it turns out.
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just thought of something :
    I looked at some cut off the axle shock mounts from an old GM axle . Weld those to a flat plate , and you got a dollar down Ford shock tower :D
    You could also use a scrap piece of square tube , cut some off the bottom ( sides and front ) and drill the holes for the bolts and shock eye .
  11. badger red
    Jul 30, 2004
    208
    south central KS
    Scott, I'm not sure how little you're wanting to pay for a set, but I bought mine new from the FURD dealership and they were cheap--maybe $11 a piece?? It's been a while, but I was blown away at how cheap they were.
    Jeff
  12. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I may end up doing just that. I was formulating a similar plan on the drive home this evening. I like making my own stuff when I can.
  13. Desert Yeti
    Desert Yeti 1/2 ton status
    Mar 20, 2003
    320
    Tucson, AZ
    Thanks to MRK5 for the pic of the "old" style ones (I guess?) I'm getting ready to do something to extend my shock mounts and was wondering about the difference between these old ones and the "newer"? SD ones... which one would work better as far as locating the upper shock mount as high up as possible? Anyone got a pic of the SD part?
    Thanks guys!
  14. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    Yep that is the older style. Not sure if one is taller than the other. Most guys prefer the newer ones because they are cast and are secured with 3 bolts. The down side is the single shear mounting stud.
