Olds 455 Rocket into a '79 K10?
Discussion in 'The Garage' started by kennyw, Apr 6, 2004.
  1. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Olds 455 Rocket into a \'79 K10?
    Looks like I'm trading my way into a healthy 455 Olds Rocket motor and thinking about using it in my '79 K10/20 to replace the tired 350. I know there are some adapter plates available cheap for the bellhousing bolt pattern but what about the flywheel? Are they internally or externally balanced on the 455? Anyone know about motor mounts?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Re: Olds 455 Rocket into a \'79 K10?
    I may be wrong , but since all modern Olds V-8's are similar (deck height determines big or small block) and the Olds diesel was based on these and offered in Chevy trucks, you could probably use mounts from Chevy truck with Olds diesel engine. The other questions I am not sure about. /forums/images/graemlins/k5.gif
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    That Olds motor is one of the widest engines ever built. The exhaust ports are also very low. You will probably need some custom headers for it to fit. /forums/images/graemlins/grind.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    He could probably modify the exhaust from a Chevy truck with Olds diesel to fit in the engine compartment. 455 is just slightly taller deck height. /forums/images/graemlins/k5.gif
  5. dyeager535
    26,980
    BBO is just about 2" wider across the intake, FWIW. If a SBO will fit, so will a BBO. (or darn close) /forums/images/graemlins/smile.gif
    They swap BBO into cars that were never designed for anything but a SBO/SBC (78-88 A/G bodies) so fitting one into a truck won't be a challenge, at least as far as size is concerned.
  6. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    A friend used Chevelle headers in his Jimmy when he swapped in a 402BBC. I wonder if Cutlass headers would work? It will should be a torque monster. Go for it Kenny.
