OMG! crooked body **DAY THREE RECOVERY**
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Jul 18, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I did something I thought wouldn't be a problem today... I drove thru a concrete drainage ditch that is about 16" deep, and 6' across. I got thru it NO PROBLEM. I did wack the gas tank shield a bit.. and also hit the rear pass shackle a bit too... that is a little bent.
    WHAT I REALLY DON'T LIKE IS - the fact that the passenger front of the truck is DROOPING! I looked for cracked sping packs, broken steering box, and anything else that looked outta wack. I did hi-lift the front bumper on each side looking for odd stuff... and I noticed that the spring pack on the passenger side expanded quite a bit compared to the drivers side pack...
    Other than that - I noticed that the rear suspension feels VERY loose compared to the front susp... the body did rotate about 1/4"-3/8" on top of the frame, but all mounts are intact and SEEM to be fine with zero slop... and... hmm... can't think of anything else.
    I'M GOING KRAZIE! /forums/images/icons/crazy.gif I can't believe that I've done this to my truck! What am I going to do???? /forums/images/icons/confused.gif
    I also did PARK the truck in the ditch... one rear tire in the ditch, all other 3 still up higher, a little flexed but NOTHING serious. I left it there for 10 hours. Could I have re-arc'd the springs? Problem with that thought was that the drivers front was compressed while the pass. front was dropped expanded. And now the reverse is what I am seeing.
    AHHH!!! Someone please tell me what I've done... I can't stand it! /forums/images/icons/tongue.gif /forums/images/icons/blush.gif /forums/images/icons/confused.gif
    -Dan
    *** SEE BELOW FOR UPDATES! ***
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Re: OMG! What have I done.... crooked body
    sounds like you left the frame twisted during that time and it wants to stay that way now /forums/images/icons/smile.gif
    Honestly I'd just give it a few days to settle down. Go through the ditch again with the other site flexing, or just let it go for a few days. It should be fine.
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    A guy in my club parked is jeep on our clubs RTI ramps one day in front of his tire store for effect. When he pulled it off in the afternoon it was leaning real bad, he did the opposite pose the next day for a few hours and it seems to have "fixed" it. Kinda scary looking at first.
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    AHHH!!!!! I am SO pissed at myself! I can't believe that I did this! This soooooo sux! /forums/images/icons/mad.gif Should I park it in the ditch the opposite way tomorrow, or just let it settle down by leaving her on FLAT terrain while I'm at work? /forums/images/icons/laugh.gif
    -Dan
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    That's EXACTLY what I did... "JUST FOR EFFECT!" I got lots of comments over the day... but I don't remember if it twisted before or after I drove it thru the ditch!
    SOMETIMES, I CAN BE SOOOO STUPID... never again park the rig flexed for the folks at work to gawk at! /forums/images/icons/laugh.gif /forums/images/icons/wink.gif /forums/images/icons/grin.gif
    AHHHH!!!!
    -Dan
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what have you done in regards to frame work?
    stitch weld the crossmembers?
    replace rivets with bolts and stover nuts?
    nothing? really nothing? that wont do at all.
  7. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I've replaced a bunch of rivets with grade 8 stuff... other than that I've never done frame work. Never knew I needed to! What actually happened to my truck today? Ideas?
    -Dan
  8. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    I've never heard of this but I hope everything goes OK for ya!
  9. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    showoff
  10. Grim-Reaper
    7,385
    Atlanta
    Ya settled the springs. Put it in the other way and settle the other side. Then it will flex better /forums/images/icons/smile.gif Drive it a few days. run over honda's and stuff. After hard wheeling in mine it takes a day or two before it settles back. The ORD Steering brace took out the worst of it. The rest is the springs are bound up a little.
  11. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    showoff
    That is too damn funny! /forums/images/icons/smile.gif
    -Dan
  12. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    So you think that I just kinda stretched it out a bit, and it will settle down after I romp on it some more? I did park it the opposite way in the ditch today... but I will only leave it there for a few hours, as to not produce the same effect in the opposite direction!!! /forums/images/icons/blush.gif
    Should I stop worrying?
    -Dan
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, quit worrying, it'll be fine.
  14. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    /forums/images/icons/ooo.gif /forums/images/icons/confused.gif /forums/images/icons/blush.gif /forums/images/icons/tongue.gif /forums/images/icons/grin.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
    Okay... but I'm still kickin myself in the ass for that dumb@ss stunt! Never again... /forums/images/icons/smile.gif
    -Dan
  15. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    My buddy's truck did that after he stayed flexed out to the max for atleast 6 hrs....it looked funny for like a day then settled back in later....I wouldn't worry much
  16. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Re: OMG! crooked body **DAY ONE RECOVERY**
    Okay... at work today I parked half back in the ditch the other direction. After I left it there for about 2 1/2hrs I took it out, and it seemed to sit straight.
    After I drove it home, and then drove to a buddies house... the friggin' front end is saggin again! /forums/images/icons/mad.gif Totally sux...
    I'm just real sad that I haven't seen it sitting straight again!
    Could it be possible that I bent the body or the mounts on the chassis?
    -Dan
  17. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    If i were you I'd park it on flat ground and loosen all the body mount bolts. Then I'd see how it sits...if it still sat low on one side I'd jack that side up a little under the frame and re-tighten all the body bolts.
    Then I'd never leave my truck crossed up for 10 hours again.../forums/images/icons/smile.gif
    Rene
  18. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    [/ QUOTE ]You don't say Rene?!!! Seriously?
    Just kidding... I DO like the idea of loosening all the body mount bolts, getting it to sit straight again, and then re-tightening them. That just might work...
    -Dan
  19. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    And you laughed at me as I went down the hill with no brakes. Now my turn. Ha ha ha ha /forums/images/icons/laugh.gif /forums/images/icons/grin.gif /forums/images/icons/smile.gif /forums/images/icons/grin.gif haha
    Okay I think we learned something here. Oh yea I thought it was funny you checked the steering box! Have you ever seen one break before? /forums/images/icons/smirk.gif
  20. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    [/ QUOTE ]NOPE - never actually witnessed a cracked frame or a CRACKED AGR steering box! I just figured that if you lost so much steering capability, and you were wandering on the road so much - SOMETHING had to be broken. /forums/images/icons/wink.gif Guess I just always wanted to see one brake - and you made that wish come true! /forums/images/icons/smile.gif /forums/images/icons/tongue.gif /forums/images/icons/grin.gif
    As for laughing at me... I figure I learned a good lesson too. So all the laughing that went on in this thread WASN'T for nothing. At least my truck and I taught everyone else a lesson on leaving a rig crossed up! /forums/images/icons/smile.gif
    GLAD TO HELP! /forums/images/icons/blush.gif /forums/images/icons/cool.gif
    -Dan
