omg its got a posi
Discussion in 'The Garage' started by bowtiewrench, Oct 24, 2004.
  1. bowtiewrench
    bowtiewrench Registered Member
    Oct 19, 2004
    24
    Woburn, Mass
    Well today I was out ripping around in the k5 and was beating on it a bit with some friends. I was trying to do break stands but it just didn't like doing it. Who ever ordered this thing with 2.73 gears was a complete moron. It started raining a bit and I tried some more break stands and sure enough both tires went up in smoke. I could not believe this thing had a stock posi on the option list when it was ordered, these trucks are hard to come by with a stock posi rear end.
    Alex
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Actually the gov lock (Posi) isn't that rare. Be careful with it though, they tend to grenade when abused too much. I have one in my 14ff but it is rendered useless when the front is locked up.
  3. bowtiewrench
    Oct 19, 2004
    24
    Woburn, Mass
    Ya I figured anything they put in that 10 bolt isnt going to be that strong. I blan to change the diif fluids front and rear and T-case to synthetic as a piece of mind, cause god knows what the fluid looks like.
    Alex
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It prolly is a gov loc, but it might not be. I know my blazer was open and it would get both tires loose, along with my friends tahoe. Ive seen other open diffs (on wet, loose pavement) get both to spin also, just like it had posi. Now I understand how diffs work and all, thats how I make my income after school, but I dont see how my open diff would get both tires loose? /forums/images/graemlins/dunno.gif In theroy, it shouldnt work.
  5. dyeager535
    26,982
    191
    Changing fluid isn't going to save a gov-lock.
    Be easy on it, or you WILL be changing the axles sooner than you think. Burnouts and the gov-lock=carnage, in short order.
    Of course, if you want to get rid of the 2.73's, have at it! /forums/images/graemlins/smile.gif
  6. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    If ya do that a couple of more times you'll be doing more than change the fluid.
    It don't take much to start the gov-bomb tickin.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sure it should. With the same amount of traction on both sides, an equal amount of torque woudl be applied.
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    But it would do it EVERY time. Thats what made no sense.
  9. bowtiewrench
    Oct 19, 2004
    24
    Woburn, Mass
    I plan on putting a locker in the rear along with some 4.10's. For now Im just going to run the 10 bolts as the should be fine for how I use the truck. I plan to build a stout 406 with an nv4500 behind it which with the way I drive is sure to cause some carnage on that piece of a 10 bolt. hey k5monsterchev what exactly do you need to adapt an nv4500 to a small block. Thanks
    Alex
  10. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have had some open differentials with a LOT of play in the spider gear to carrier area and it caused enough "binding" to make both tires spin; the pins and spiders broke shortly thereafter.
    Would a G80 in the glovebox mean it has a gov-lock?
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    From the mid 70's on in trucks , yes it would /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  12. dyeager535
    26,982
    191
    G80 appears to be any traction aiding differential. (rear only?)
    Cars used G80, and so did trucks. Very few, if any, cars got gov-locks.
    However, the GM truck manuals list quite a few different non-open differential assemblies, (gov-lock, eaton posi, cone type IIRC) so there is no GUARANTEE that G80=gov-lock, even in a truck.
    These vehicles are all so old now, unless the original owner, it's pretty much impossible to tell what the truck originally came with...the gov-locks come apart pretty regularly, and the 8.5" 10 bolt was used in lots of different cars and trucks, thus, an actual posi of some type would be a no-brainer swap into a truck after a gov-lock came apart.
  13. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the detroit locker that was available in the Eaton rearend in earlier GM trucks was listed on the sheet as G86 No-Spin Diff.
    older 1/2 ton trucks with the G80 had the generic clutch style posi, but I think the dana axles and power/trak locks had their own RPOs.
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I agree , however , my post is based on the trucks I have seen in yards and in trucks . Seems like the second gen Blazer got the gov locs exclusively . I am sure there could be others , because we know GM track record with changes to keep the lines going . regardless , I will never run one again after having a locker out back /forums/images/graemlins/thumb.gif
  15. dyeager535
    26,982
    191
    From previous posts, it almost sounded as if non gov-locks were more common 88-91 than 81-87, but that was just based on a few peoples post.
    I was quite surprised to see the different styles listed in the 1986 service manual. I too have personally seen nothing other than the gov-locks in a 1/2 ton axle.
