OMG! The 1910 Edelbrock in the cold...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Mar 9, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I went to work today, and it was about 60* outside. When i left work, it was about 25*. All I have to say is, this has to be fixed. There is no power at any speed, not off-idle, not off 2500RPM on the highway. The carb died a chit load of times before I could even get outta work's parking lot. It felt like it just kept stalling out... I even let it warm up pretty well.
    Why? And this "situation" continued all the way home for the 20 minute drive, even after reaching full operating temp. Ideas?
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    im going through the same stuff with mine, i am not impressed at all with this carb, ill keep my eye onthis post, i need some answers too... thx
    Josh
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like the old choke problem. /forums/images/icons/frown.gif
    I have the 1904 Edelbrock Q-Jet and it's the electric type. I still have trouble with it during cold start ups. Much like you explained it, too. /forums/images/icons/frown.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Choke?...is that the thing with the zip-tie holding it open/forums/images/icons/smile.gif/forums/images/icons/tongue.gif
  5. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    I had a different Edelbrock awhile back that had the same electric choke. I don't ever remember having problems getting that one to function... Will I ruin the electric choke if I take the ol' zip tie method? The Holley I just yanked off the truck had the choke tied open before I even put it on the engine!
    Isn't there an edjustment that will make movement in the elec. choke more exaggerated (sp) at the choke plate?
  6. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    on the old Q-jets there's 2 adjustments for the choke, you can loosen the three screws arouond the choke housing and turn it to change how much it closes choke on carb and then there's a little screw right under the housing that adjust's the idle RPM's this is accessible from in front of the engine, The new one maybe different.....but maybe this will help
