On a cold start is the cloud of smoke normal?
Discussion in '1982-Present GM Diesel' started by bigblock454, Jan 7, 2003.
  1. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    My 86 Burb really throws out a cloud of smoke right at startup, after that no smoke. Is this normal? Smoke looks to be white maybe.
  2. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    How are your glow plugs? They all lighting up and all in good shape? Try plugging it in for a night then start it up.
  3. marcus
    marcus Registered Member
    Dec 21, 2001
    65
    England UK
    Mine does exactly the same. On a cold start (<0 decgrees), it won't start after the first crank of about 5-6 seconds, always starts up after about 3-4 secs of cranking on the second try, with a healthy puff of smoke...
    Donlt know the condition of my glowplugs, the glow plug light somes on and cycles for a while after start up, then stops.
    Talking about glow plugs, when my alt belt started slipping badly, and the battery indicator on the dash went down to about 9-11 volts for a while, the glow plugs would cycle for along time, up to 10 mins into the journey. This stopped when I replaced the alt belt and got the battery charge back up....any idea why a low charge would cause the plugs to cycle? The temp was normal....
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    I haven't checked the plugs yet, how hard is that to do? When I plug it in it doesn't do it.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    The glow plugs are resitors, and if you know electric formulas, you would know to produce the same amount of energy, using the same resistance, with lower voltage, you need more time.
    It's like the electric stove. Put it on high it will heat in a minute, put it on low and it will take forever to heat the same amount.
    /forums/images/graemlins/thumb.gif
  6. marcus
    Dec 21, 2001
    65
    England UK
    That is a great reply....you managed to explain it very clearly in just one sentence....if only all post were like this one!
    Cheers
    M
  7. Boggeddown
    Boggeddown Registered Member
    Dec 17, 2002
    7
    Mississippi
    Try rotating the glow plugs and plugging in the block plug. /forums/images/graemlins/k5.gif
