on a drw d60....***Pics * Updates.***
Discussion in 'The Garage' started by TXsizeK5, Jan 2, 2004.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    are caliper mounting brackets the same as SRW? how do you pull the caliper off a DRW d60 i am having a hard time taking this apart. if anyone has a pic that would begreat. im looking on pirate and it doesnt seem to be the same.
  2. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Re: on a d60 drw....
    I have a SRW D60 under my Blazer and a DRW D60 under my dually and as far as I know the Caliper mounting brackets are the same on both. I have had the calipers off of both and they both came off the same way. Let me know if you need any specific info.
    Russ
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    They are the same. Remove allen head bolt, drive out retaining clip, remove caliper.
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    any advice to getting out spindle bearings, im having a hell of t ime
  5. nvrenuf
    Jan 7, 2002
    13,084
    251
    Mobile, Al.
    Take a long, flat style screw driver and bend the last 2" or so to a 45 degree angle. With the spindle off, go in from the outboard end and place the screw driver behind the bearing and drive it out.
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
  7. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    There are no caliper bolts holding it on. If you look at the bottom of the caliper there is a hex bolt. Take it out and you have to drive out the clip and tensioner. Then lift the caliper up and out. I can take some pictures in the morning when there is daylight if you still need them.
    Russ
  8. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    yes please
  9. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
  10. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    thanks. I think I stripped that /forums/images/graemlins/eek.gif
    I got one off after much struggle with a small allen key. second one i definately stripped, so I drilled it out and got it off... one spindle came off nicely the other is pretty froze on. =(
  11. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    beef cake! [​IMG]
    Froze up spindle
  12. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I've got everything out except for the lower kingpin dust cap and bearing race. Banged the WEE out of it... no go. We got one dust cap off the other just broke down the middle from the drive. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    Any adivce?
  13. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Sorry, I don't have any advice for you on getting that race out other than keep pounding on it. I do have a question for you though. Are you using a kingpin rebuild kit and if so, where did you get it from and what did it cost you? i am planning to rebuild the outer ends of my dually axle and am looking for the most complete kit at the best price.
    Thanks,
    Russ
  14. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Randy's Ring & Pinion for.. 40 some odd dollars per side.
    One of my king pins was immaculate the other had some surface rust but not pitted or anyhting. my springs and bushing were also not bad. but im going to replace
    everything but the kingpins themselves, as they are a be-otch to get out I hear.
    I can give you my kingpins that come in the kit if you can just get bushings/springs from ORD. but then you gotta rebuild the lower kingpin, so I dunno.
  15. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    With much persuasion, the lower kingpin race & dust cap came off... notice the dust cap pictured, broke it while beating the crap out of it!
    Here's the housing with pinion and kingpins
  16. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Kingpin Rebuilds from Randy's
    Starting to Paint
  17. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    Almost done, just need a steering arm, and a snap ring and outer locking hub.
