? on axle splines
Discussion in 'Pacific Region' started by hd-10, Feb 8, 2005.
  1. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    just to make sure dana 44 axle (30) splines can be used in my 10 bolt axle which also has (30) splines.
    also don't know if it's true or not but i herd that you can put dana 60 outer stubs on the dana 44 shaft is this true or just bad info?
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    No the d44 and 10 bolt axle shafts are diffrent.. Slight diffrence in lenght..
  3. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    pressure angle of the splines is different too.....
    If I recall, Steve Watson was succesful at interchanging them in one direction (I don't remember which....) but they wouldn't work swapping the other way...
    Might call him and ask..
    Marv
  4. hd-10
    Jan 31, 2004
    188
    lemoore, ca
    thanks for the info i will call steve up today and ask him.
