on board air help
Discussion in 'The Garage' started by Disturban, Mar 17, 2006.
  1. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    Bought a viair compressor for my 87 burb...it's rated at 23 amps, and has a 30 amp in line fuse.There's not alot to this equation, but the fuse keeps poppin.I've checked the ground..it's good. I tried to just bypass the inline fuse, but that just super heated the wire.The compressor seems to work fine when I hook it up to a battery charger set at 6 amps. Help? Ronwhistle@cox.net
  2. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    How much, and what gauge wire are U using on the + side?
    Is the + conection a good clean conection?
  3. Disturban
    Mar 9, 2006
    120
    Phx,Az
    I'm just using the wire that came with it..it's hard wired.It's mounted on the driver's side wheel well, the wire runs around the firewall to the battery.First I tried hooking it up to the terminal that's by the brake booster, but that popped it too.
  4. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Check the draw with a VOM. You may have a bad unit. The equipped wire should not get hot.
  5. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Make sure you didn't inadvertently cut the insulation on the wiring causing a short to the body. Sounds to me it's a bad unit.
  6. Disturban
    Mar 9, 2006
    120
    Phx,Az
    Well you guys have confirmed what I'd figured....just wanted to make sure I wasn't being a retard. FRUSTRATING!!! Thanks for the responses!
