on board air is cool, but what about on board 120VAC
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Jul 23, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    was thinking it would be great to have a small generator say 1500-2000 watts using an old A/C clutch and let it be driven by an add on pulley
    any ideas or experience
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Alot of fire apparatus/ambulances have an engine driven generator similar to that. I don't remember the names of any manufacturers offhand, but they do work extremely well - enough to run 3 sawzalls at once from my personal experience.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What you are looking for is called a power inverter :)
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  4. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Inverters feed off the alternator, don't they? What I'm talking about is actually a seperate generator with an A/C type clutch on it, controllable from the cab.
    Generic Signature
  5. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Yea, Trucks TV just put a HUGE generator on a big Ford work truck a couple months ago. You could probably email them for some info.
    '73 K5
    Chevy good...Ford bad
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Seems a high capacity inverter with a small 'pancake' type compressor could work.............a generator with a real compressor would kinda take up a bit of room.........don't think bringing one along for wheeling is in my cards anyway. Good idea if you could get it to work............
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.alloffroad.com>www.blazzinor.alloffroad.com</a>
  7. 89Jimmy
    89Jimmy 1/2 ton status
    192
    Northern N.Y. east end of Lake Ontario
    You are talking about a 120v generator head. Northern hydraulic sells them in their catalog. Some of the "alternative energy" websites list them also. Some are made to couple directly to the crank of a small briggs type engine, and some are made to belt drive with a pulley. The pulley style will tolerate the side load on the bearings. The direct drive units do not last long when belt driven. Most of them regulate voltage by RPM. Correct voltage is usually produced when the unit is turning 3600. You would need to calculate that based on pulley sizes and engine rpm.
    John
    So MUCH to do, So LITTLE cash.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The fellas on Trucks TV installed some mongo generator under the hood of a Super Duty Ford a while back. You might check out their website for details. <a target="_blank" href=http://www.truckstv.com/>http://www.truckstv.com/</a>
    And yes, the generator must spin at a certain RPM in order to put out the correct voltage.
  9. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    that is exactly what i am looking for, i just did not want to say that i needed to put ot on my 99 f-350 superduty. we need a way to have 120vac with out the pain of toting around the 5500 watt generator, not to mention the noise level. and the invertors just do not have the capacity
    i will check out the site
    thanks
    chris
    what's in it now?
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    also you need to wire in a voltage reculator. that way if for some ODD reason your negine spikes you dont fry the item being used and even a capacitor (sp?) for any voltage drop off. a cap for 120v ac is BIG. nothing ou shouldnt have room for. you can spend a few bucks and put a dual alternator setup and a very nice inverter. you will be able to save space that way. also look into tow trucks. they have them some times.
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  11. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Well sence we got off the subject I saw that Dodge is going to come out with a hybred truck. It will be able to use the generator as a 120v power supply. I thought that was a great idea (they want to market it to contractors).
