On Board Air Question?
Discussion in 'The Garage' started by duece21, Jun 22, 2004.
  1. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I was reading the tech article about OBA and was wondering why you have to change the oil in the compressor, that and why change it to motor oil? Yorks come stock with ester oil, is it b/c the oil is contaminated w/ freon? If so I have a brand new york that has never been run, so do I still need to change the oil to motor oil or keep ester oil in there.
    Thnx
    Jesse
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    From everything I read the only reason they switch is becuase you carry motor oil in your truck already so if you need to add oil its in the truck.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you might want to pm muddytazz i thing he is in the process of dooing this alos onboardair dot com has all the stuff you need for the york compressers /forums/images/graemlins/peace.gif
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I don't think that the compressors are too picky about what you run in them. I put Mobil 1 10w-30 in my York since that's what I run in the engine.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Straight from Onboardair.com
    For On Board Air, you can use a typical motor oil (10w30 for example) in the compressor. Some components in the OBA system is not compatible with synthetic oils. Caution must be used if you plan on running a synthetic oil.
    /forums/images/graemlins/thumb.gif
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Whoopsie! Guess I should take out the synthetic then.
  7. duece21
    Jan 18, 2004
    501
    Aurora, CO
    Thanks for the info /forums/images/graemlins/waytogo.gif
