On Board Air
Discussion in 'The Garage' started by ProJunkRacing, Apr 26, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    Who Runs onboard air?
    I got a deal on a used york for 46 bucks shipped to me and was wondering who has one how much they spent on it and if it was a good investment... i want it to air up tires air tools and etc let me see some pics also who has a serpantine setup with theirs . i was thinking of removing me ac pump (not functioning, and putting it there my serp setup came off a 4.3l truck
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the york does not fit in the serp bracket very well ( i have tried), plus the serp pulley costs around $100, your best bet is to mount it on the drives side and run it off the alt, you can get a new pulley for around $40 that allows you to run a v-belt off the alt
  3. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Try onboardair.com they might have the bracket you need if not you need to make one and that can be a pain!!! But in the end I think its very good investment . But can cost $200-$300 for every thing else
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I run OBA and there are a couple pics in my gallery the last i looked. I got everything other than the compressor itself from www.Kilbyenterprises.com. Mine is a serp set-up also. I even had to buy the serp clutch/pulley from them and i spent about $500.00 on everything including the bracket kit they sell.
  5. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Make shore you have a long stroke pump frist . The site will show you how to
  6. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I've got a medium stroke york and I plan to use it with the kit one of these days. OBA said that it would work fine but it's not totally ideal. Seems to me it was going to cost around 7 bills at the time using my own compressor. Having a bigger tank will help with a medium stroke compressor as well. I've never seen CFM numbers though.
  7. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Maybe if you use a bigger pulley it might help . Max rpm is 1200-1400rpm . $700 is alittle high I think I'm going to look for a site I saw , to do it for cheap
  8. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Man...That $400 15 gallon Powertank isnt looking too bad.
  9. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    yeh but try finding a place to fill it in middle of the woods!!
  10. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    MY OBA SETUP
    I made my own bracket and manifold (which I make and sell BTW :thumb: )
    Check out my write-up. I think I spent a total of $75. That was with $25 york, 2 - 5 gallon air tanks and everything else.
  11. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Is there a way of telling what stroke it is without having the pulley off?
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    You can read the numbers on the name plate/tag on the side too
  13. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The three stroke numbers are: 10 = long stroke, 09 = medium stroke, 07 = short stroke.
  14. the beast
    the beast 1/2 ton status
    Oct 15, 2003
    535
    Providence, RI
    Tazz, how much for your mounting bracket?
  15. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    email me at muddytazz64 at hotmail dot com since I can't pm you
  16. the beast
    Oct 15, 2003
    535
    Providence, RI
    E-Mail sent :waytogo:
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    back at ya :thumb:
  18. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
