on-board air
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bandit, Jul 14, 2001.
  1. bandit
    bandit 1/2 ton status
    Mar 4, 2001
    690
    Ellensburg Washington
    Im seting up a on-board air system useing a york compressor out of a 77 ford any one else used a york on there sb chevy i want to see pics of how to mount it and run the belt(s) any help or ideas would be great!!!!!!!
    by the way i think il take tons of pics and then do a write up on it and put it on a webpage
    AJ
    Soon to wheelin spot near you
    Project Harvey[​IMG]
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    This may help out: http://www.K5.rockcrawler.com
    *<font color=red>under construction</font color=red>*
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Cool deal! I'm trying to do te same thing, but keep getting bogged down with repairs...
    These guys cater to Jeeps, but info is info when building this stuff: http://www.homestead.com/vj40yorkonboardair/index.html
    Shoot, I know there's a guy that did a real useful write-up somewhere on the net on a 350sb with a York for on-board air in a K5 or K10/20/30, but the link is on my work computer (and wife just got home, so time to sign off...).
    Keep us updated, and good luck!!!
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  4. bandit
    Mar 4, 2001
    690
    Thanks for the info boys hey new york if you wouldnt mind when you go to work grab the URL for me please any others with ideas???
    AJ
  5. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    cheap easy and still works!!!
    <A target="_blank" HREF=http://www.geocities.com/spencerhut/truck/air.htm>http://www.geocities.com/spencerhut/truck/air.htm</A>
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Yepper, that's the one I meant...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    bandit,
    you may want to search for some early chevy vans. they also used the york compressor. i was going to go that way but the accessories in post1stgen blazers are different. also the water pump is longer in post1stgen blazers. I just fabed my own. it's basicly "T" built from a 3/8 slab of metal. It bolts to the front of the cyl head on the passanger side. I'll post some pics later.
    I also added a 3gal airtank in front of the gastank, above and a tad in front of the pumpkin. i had to(excuses, excuses) install a 2" body lift to fit it in. I am running stock suspension with a 2.5" block on rear.
    I just finished my setup this weekend. I aired up my 33s in no time.
    ARQ.
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
  8. Adrock
    Adrock 1/2 ton status
    214
    Marlboro, MA
    ya. fabbing up the bracket wasnt to hard. give it a try. that the only way you'll learn. its start to get fun after a while. good luck. its worth it.
    Adam
    a.k.a. Adrock
    88 Chevy Blazer FI 383
    "With great power there must also come great responsibility" -Spiderman
  9. bandit
    Mar 4, 2001
    690
    yea i didn figure it would be to hard ive many alt. brakets at work i guess ill just jump into it after my hand heals
    AJ
  10. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    Just something i've been thinking about, could a smog pump be turned into a air compressor? Just a thought i have been beating arouund!stupid?
    thanks
    baldbandit
    "Have you driven over a F@RD lately!!
  11. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    No an air pump wont work they dont build enuff pressure. They do make a great crank case evacuation pump tho!!
    Out of 100,000 sperm, YOU were the fastest?? [​IMG]
  12. bandit
    Mar 4, 2001
    690
    never dealed with a smog pump so im not sure but iv never heard of anyone useing one
    AJ
