on board air?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jim82, Jul 3, 2000.
  1. jim82
    jim82 Registered Member
    Jun 27, 2000
    71
    Bay Area
    Do any of you have on board air of any kind? How is your sys set up? I was just digging around in the garage and found an air compressor from an eighties caddy. It was used for the air shocks for auto leveling. It seems like a sturdy unit, the motor is about the size of my fist and pretty heavy. I was thinking maybe get a 3 gallon tank and mount it to the frame. My main use would be to air up my 32"s. How long does it take to air up your tires?
    I was also looking at the ac compressor systems. They say you can run air tools off of it, but I don't think it would help my gas mi any running two compressors. Just some thoughts..
  2. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    The Caddy compressor sounds cool. Try it! I had a '65 Chevy wagon with a vacuum operated compressor for the OEM air shocks. I have never seen one since. I have tortured an ARB compressor in my K5 since 1989. It's still ticking.
    SteveB
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I think the CO2 tanks are the way to go, no pump, no electrical problems and you can buy a tank at most fire ext. refill places and save a bundle over others. I have a 20 lb tank and I can air down and back up 60 times before I have to refill-and I run 44's. You can run air tools and ARB's if you want.
  4. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I have converted a stock G.M. Pancake style Air Conditioning compressor into my on boar air setup. I have a 3 gallon tank under the hood and another 3 gallon with a 6 gallon under the floor of the bed above the rear driveshaft. They all work well together and I can air my tires up as fast as any regular air compressor.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  5. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    I just helped one of my friends put onboard air in his Jeep last month. He got an air conditioning compressor off a '70 AMC Eagle from a junkyard for about $30 and a mounting bracket from onboardair.com. The compressor puts out 10 cfm at around 2500 rpm's and charges a 5 gallon tank to 115 psi in about 20 seconds. The whole project cost about $100 (fittings, tank, regulator, etc.) and he can run an impact wrench with it. As soon as my truck comes back from getting a new tub, I'm going to put the same system on it.
    Joe
    Rochester Institute of Technology Team Mini-Baja
    88 Jimmy
