On-board air?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Feb 2, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    I was wondering what it takes to make an on-board air system work in a 1987 Gmc Jimmy(fullsize). I was told that you will need a york compressor, which would work best. what else will i need? The vehicle has A/C could i run the air system through that.Or if not will i have to take the a/c compressor of rendering my a/c not functionable?Please share any knowledge that you know that could help me.
    /forums/images/graemlins/k5.gifThanks, Marshall /forums/images/graemlins/usaflag.gif
    350/208/3.73Gov-Lock/31"s
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You cant run it through you a/c system, because you would put all you freon in you tires. You have two options, one remove your a/c and put the compressor there, or two mount the york compressor somewhere else so that way you can have both.
    Dan /forums/images/graemlins/burb.gif
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
  4. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    has anyone done this one before? i'm sure people have, but what kind of bracket did you use, or fab up? pics would be helpful as i already have the york and control box too
  5. Marshall
    Apr 8, 2002
    204
    LiveRmore,CA
    what is a good york compressor(model)? I was told that a model 210 is a good one.Which is better Long stroke, short stroke or medium stoke?Does the discharge direction matter?
    Thanks for any help provided.
    350/208/3.73Gov-Lock/31"S
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Did you read the article Triaged linked for you? /forums/images/graemlins/smirk.gif /forums/images/graemlins/rolleyes.gif
    Answers: Long stroke is better because it moves more air per cycle. Discharge doesn't matter - just hook it up accordingly. Article also tells you how to identify the long, medium, and short stroke compressors.
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    You want the last 3's to be either 210R or 210L. Discharge side doesnt matter.
  8. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    He has a 87...onboardair.com makes a bracket for that motor. If you have something else (non-serpentine belt) you will have to make your own bracket...or find one (like I did) for a SBC in the junkyard (you are not likely to find one...I got it out of a 73 p/u with dealer installed air)..
  9. 85burban
    85burban Newbie
    Feb 3, 2003
    3
    yeah, York 210's are the most saught after. they do make 212's but are rare and expensive. there is 206,208,210, and 212. basically the last set of numbers is its volume of air it pushes 6cfm, 8cfm... 210's can be found at junkyards for cheap.
    www.onboardair.com is a great site. I installed a OBA system on my Jeep
    MY OBA setup.
    since you have a lot of room for a tank, I suggest a bigger tank. anyquestions, just email me. tj@getitup4x4.com
    I have a list of parts and prices on there. I did a lot of research to find the cheapest things.
    I'm not sure if you have serpentine or v-groove clutch, but the serpentine clutch is rare and $100 new. you can convert the v-groove to a serpentine one, like I did on my site.
    It is a sweet mod that really helps.
  10. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Somewhere I read the stock sanderson compressor makes a good one too. Someone modifies it with a grease zerk to lube it so you don't have to get a seperator Has anyone ever done the sanderson compressor to air compressor /forums/images/graemlins/rotfl.gif
