On board shower heat exchanger for sale/disc conversion for 14bff
Discussion in 'General Parts for Sale' started by cybrfire, May 5, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    4.5" Diameter body. 14.75" long body is PVC. 5/8" hose connections. No leaks. There is 13 feet of copper tubing in there. PRICE LOWERED.
    How's 35 bucks plus shipping sound.
    disc brake conversion. <font color="red"> sold </font>
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    TTT edited.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Nobody needs an onboard shower! You've been wheeling hard all day on dusty trails. The day is over and its time to set up camp. How are you gona get all that grime off. You need a hot shower!!!!
  4. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    If I hadn't just blown $500 on a fence in the backyard I'd be all over that heat exchanger.
    If nobody grabs it by my next payday (20th) I'll definatly take it.
  5. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    how does the heat exchanger work? is it easy to plum in and what other parts would I need?
    /forums/images/graemlins/burb.gif
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    It's really simple. The copper tubing you see sticking out the ends is your clean water intake and output. One end you would hook a garden hose to with hose clamps to an attwood submersible non priming 12v pump. available at RV places. They are pretty cheap. The other copper tube is attached to a shower head or whatever via garden hose. Usually routed back to the firewall and up the hood. Open your hood and its pointing out and at you. The barbs hook inline with your 5/8" heater hose. They are plumbed into the tank which heats the water going through the copper tubing. You can have hot showers until you run out of gas. Some people have put valves inline with the garden hose to regulate flow and therefore adjust the temp but I don't think its necessary.
    Here's your parts list:
    garden hose, number of feet?
    4 5/8" hose clampsattwood pump part no. V1250 submersible bilge pump. No priming necessary. As far as wiring the pump you would need to take a power and ground up to the battery. I've seen people use lamp cords. Simple. Attach to battery with alligator clips.
    That's about it.
  7. pfloyd_1
    pfloyd_1 Newbie
    Mar 31, 2004
    4
    Reno, NV
    Some info on the Conversion parts, who made them, what calipers do you use? Thanks.
  8. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I made these brackets for somebody and they didn't pay up. Anyway they use a 3/4 ton front caliper like say 1980 year and matching part no.'s will work.
  9. pfloyd_1
    pfloyd_1 Newbie
    Mar 31, 2004
    4
    Reno, NV
    So you could use a set of stock 3/4 ton front roters, like off a d44? How thick of plate did you use?
  10. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Yep 3/4 ton off a dana 44 will work. I used 3/8" thick plate for all peices.
  11. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    does the exchanger have to mount flat or can it go up and down. I'm kinda limited under my hood. Thinking of just building one to bolt to the bottom side of the hood and going as big as I can. Like 2 feet long or so out of 6" PVC.
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    You can mount it any way you want to. /forums/images/graemlins/thumb.gif More depends on the strength of the fresh water pump and how high things are from the source.
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
  14. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    once more then we gona go ebayin'
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    One more time then its off to ebay. Price lowered
