On board welder? alternater ??
Discussion in 'The Garage' started by bablazer73, Sep 7, 2002.
  1. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    who has a welder onboard, brand, and likes/dislikes. What are the alternater specs?? I have a local rebuilder than can build me anything. He put together a 143 amp stock cased unit for me under for 90 bucks, but I wasn't sure if that was gonna work. He says he can still go bigger, just didn't have parts there. the 143 was at 6300 rpm, will never see that!! was 65 amps at 2500. Whats needed??
  2. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    back to top
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I have a mobi-weld on my toyota. The alternator is Delta wound so the RPMs need to be higher than idle to charge the battery. Above idle it works fine. Welding output is controlled by the speed of the alternator. It's a great little machine. I used it to build my shop. I've repaired a coilover for a kid on a banshee. It will weld 5/16 one pass. Mine is not the heaviest there is and requires 3/32 rod. I can't say there is anything I dislike about it except maybe not being able to weld 14ga without blowing the occasional hole, but that could just be me.
  4. Grim-Reaper
    7,385
    Atlanta
    www.pirate4x4.com in their tech section is how to build a mobile welder from parts you can get from NAPA and your local welding supply. That have some good info on alternators that they used.
