??? On Dana 60 Swap and Sway Bar
Discussion in 'The Garage' started by BrianDamage, Feb 11, 2007.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    well, finally got my K5 pulled in the shop and yanked the stock rear end out last night. I've had my 14 ff and dana 60 for nearly a year now....but with moving and everything, just now able to get started.
    anyways I was noticing on the stock front axle that the sway bolts to the stock spring plates on each side. should I have bought stock dana 60 springplates if I had wanted to attach my sway bar (I'm assuming they are similar to the ones on the 10 bolt, just bigger?)....I have the DYI4x4 plates now, but I would really like to have my sway bar hooked up. I'm not going to be doing anything that would require having it unhooked
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Then why don't you sell your 60 for a profit and go back to whatever axle you had before.
  3. sweetk30
    Nov 1, 2004
    25,542
    539
    horseheads , ny 14845
    do you have a 4" or bigger lift? if so you dont need that limiting bar.
  4. BrianDamage
    May 14, 2001
    753
    Alabama
    why don't you actually answer my question, or not post?
  5. BrianDamage
    May 14, 2001
    753
    Alabama
    planning on a 6" lift and 35's
  6. sweetk30
    Nov 1, 2004
    25,542
    539
    lift springs are much stiffer than stock. and with positive arch for lift the body roll will be a lot less than before. most say taking it out even on street only lifted trucks makes it ride better.
    search for sway bar and you will find lots of good info on hear.
  7. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Lift it and 86 the sway bar. I am running 6" springs and taking the say bar off made it handle bumps... better. I dont even notice it is not there in the turns.
  8. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Yes, you will need stock style plates to mount it. They are just like the 10 bolt only bigger.
  10. BrianDamage
    May 14, 2001
    753
    Alabama
    sweet truck :D
    yeah I was a little worried about loosing it....some of the places I go to hunt are so curvy they could be used for a sportscar commericial :( which I don't ever drive that fast, but still didn't want to have and try to react in an emergency situation and go off the road
    being that I'm not doing any rock crawling or anything, I didn't think I needed to 86 the sway bar....
    I guess when I get my new springs, I can try it like I have it set up, and if for some reason I don't like it I can try to find some of the stcok spring perches
  11. sweetk30
    Nov 1, 2004
    25,542
    539
    i see plates on evil bay from time to time. i think 2-3 sets on now.
  12. FoolSizeK5
    FoolSizeK5 Registered Member
    Jan 4, 2006
    37
    Grovetown Ga
    I wouldn't worry about it.
    I have a 85 i've run without the sway-bar for over a year. Recently decided to make that one my dd kinda like driving the Vortec around on the road. I've only got 4" of lift though. I put the sway bar back on a couple of months ago just to help remind me not to take it back on the rocks. But i didn't notice any change from off to on while driving it on the street. But it's just my opinion. Just hope i can get 73 built with an S10 cab 60 and 14ff with ORD doubler before i take the sway bar back off to go play.
