? on gm 205 transfer case
Discussion in 'The Garage' started by weaves jeep, Mar 8, 2006.
  1. weaves jeep
    weaves jeep Newbie
    Mar 8, 2006
    florida
    need to know if there is a difference between a 1970 gm 205 transfer case and a 1973 205 transfer case ....thanks
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    not sure if there is much difference between a 70 and 73... most of the differences have more to do with which inputs/outputs they have. The former is determined by which tranny is in front of it. Later depends on year...
    j
  3. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The only difference that I know of between 1970 and 1973 is the 350/205 versions where the adapter has an extra support bearing in it. GM did away with it after 1972.
    Tom
  4. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    Yea that sounds right....over the years I have seen that the pre 73 205's with a 350 trans had a bearing supported drive sleve in the adapter.
  5. MEK5
    MEK5 1/2 ton status
    Jan 21, 2006
    244
    Maine
    IMO the early 350 adapters were better with that extra bearing,I would think that the splines would get less wear.Have you ever grabbed an auto tranny output shaft,not real rigid.
  6. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    It's a shame that the "bean counters" make the engineer's do away with what is not absolutely needed as the years go by. Just another example of how they don't make em like they use to........
    Tom
