on my knees, starter troubles
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AussieK5, Aug 30, 2001.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    This will be staight forward stuff for somone, I've got a starter/ign prob (would tear the whole thing apart, but had a shoulder reconstruction on Tue). When I try to crank all I get is a sound like the solenoid is engaging/disengaging real fast, this happened last week and I replaced it with a spare new one. It happened again the next day but cranked on the 2nd or 3rd go, since then no probs, now all I get is this clicking sound. Its a 73 350, all the connections are tight and clean, (did it last week), as far as I can tell there is no relay in my system either. Any thoughts-Thanks in advance.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Whatever you decide to do, as far as buying another starter, get a new one or a lifetime warranty starter.
    I had some trouble on my '85 K30, which I've had for 5 years now. In those 5 years, I have replaced 5 starters. [​IMG]
    My problem was shimming the damn thing. And the fact I was buying the 'el cheapo' starters. Even one new one I got lasted me one day!!! [​IMG]
    I finally got fed up and bought a lifetime starter and it's still in the truck today. No more grinding or shims. No complaints either.
    So, get a brand new one or a lifetime starter and you should have no troubles for a while. [​IMG]
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Sounds like either a bad battery or cables, probably the cables. Try running a jumper cable from the battery to the solenoid and see what happens. Also try running another from the negative post of the battery to the frame.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    If you know your battery and starter are good then I'd run down the cables and make sure they are in good shape.
    I've had the same problem all week. I went thru to batterys, tested the starter and tested the alternator to make sure they were good. Since I had the alt and starter out I yanked out the cables and found that my cable to starter from the battery (and a couple of other wires) was burning on my exhast manifold and grounding out causing one hell of a headache.
    <font color=blue>Professional <font color=red>JEEP EATER</font color=red> it's a population control thing.</font color=blue>
  5. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    When I read your post I thought yeah yeah its all good, then I thought, no no go and check again. Guess what earth prob. A big thanks for smacking me in the face with the obvious. I found it hard to believe any compnents would be at fault, new batt 700cca, leads as thick as my thumb, starter that cranks as quiet as a mouse w/o shims, so it had to be down to who was doing the spanner work, I didn't crank down the '-' post nut, finger tight only. A little to self sure me thinks.
  6. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Don't feel bad[​IMG]! I replaced my battery a couple of weeks ago, got in the truck, hit the key and nothing. After throwing a fit, and throwing the hood open - some idiot neglected to put the cables on[​IMG]
  7. hey, on one of my 350 blocks, i couldn't seem to shim it so that it wouldn't bust the nose off the starter, i went through about 4 of 'em, and i think the problem was compounded by a bad flywheel after all that.....
    what's the deal on the cheapies, are the bodies not correctly macined to the proper tolerances or something??
    rgrgegre...... greg
  8. dyeager535
    26,975
    I don't think thats the case. AFAIK, all the starters you are buying are using GM nose cones, which will set your starter gear/flywheel distance. Gm did make cast iron nose cones, but then your block would probably bust : )
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
