? on my other vehicle (396)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nyyef, Jun 18, 2000.
  1. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    i have a 69 chevelle SS with a 396 & M22 4speed. it has been rebuilt with a mild summit cam, a mallory HEI, and CR has been brought down to 9.5:1, everything else is stock. the car isnt run much but runs good until tonight(i pamper it).
    i just now took it out for a drive, when in second gear at about 3500rpm it suddenly started making a popping sound. i have never heard a sound like this before. the best description is 'pop, pop, pop, pop...' but very rapid. it does this in first(3000rpm), second(35000rpm), third(3500rpm) but does NOT in fourth no matter what rpm i floor it at.
    any help would be much appreciated.
    Knife.
  2. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Does it lose power at the same time? My wife used to have a Lumina that would do that. After a while I figured out that it only did this after I hosed the engine compartment down.
    After a while it would dry up and quit doin it. So if you hosed yours down recently, that could have something to do with it.
  3. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
    Look at the carb. I assume you have a Holley which is notorious for blowing the power valve.
    Shawn
    87 K5
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
  5. nyyef
    May 16, 2000
    479
    Saudi Arabia
    it has not been hosed down, the carb is a quadrajet-rebuilt and i am know doubting the quality of the rebuild, and the timing is adjusted.
    i am pulling the plugs, i think it may be running lean.
    but i just wanted to hear some opinions before getting in to it this weekend.
    Knife.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Sounds like it may be cross firing between two plug wires. What kind of dist. cap are you using? It is not one of the crossover style caps is it?
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
