? on offset pin 1 inch add a leaf
Discussion in 'OffRoad Design' started by wayne, Jul 24, 2001.
  1. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Hey Stephen it looks like I am finally getting ready to order all my stuff from you and wanted to know does it cost extra for the offset pin location in the add a leaf. I spoke with Steve Fox on this and he said to go with 1 1/4 inch offset because he thinks his with 1 3/4 inch offset is to much. Thanks.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We may put a 1" and 1 1/2" on the same block for the production kit, that way you have your choice. Final price isn't set, it should add to the price since we have to do more hand fabrication work on them, but hopefully won't be too bad. Sorry it's a little vague, we're just not up to full speed producing them yet.
    Making the world better, one truck at a time.
    SW-ORD
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    How much will the offset add-a-leafs cost per pair? And is there a additional charge for a angle on them to help with the pinion angle? thanks
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  4. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    You can get something to offset the pinion angle? I'm definetly interested in that!!
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    The ones that I pretty sure we are talking about are actually relocating blocks for use when you use the shackle flip. When you install the shackle flip it moves the rear axle forward in. These relocation blocks simply move the axle back towards the rear of the vehicle to its stock location or real close to it.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We have cut them for pinion angle correction before, but I'm not sure it's going to be something we can do as an option due to having to set up to mill them each time, or having to keep a herd of different sizes available. We're definitely looking into it, we can solve a lot of quirks all at once with the right part.
    SW-ORD
  7. Mreetz
    Jun 26, 2001
    1,282
    That'd be great for me. I put on a 4" lift and would really like to realign that angle. Let me know if you're going to be setting up to cut any like that, and put me down for a set.
    Thanks!!
    1984 K-5
    4" lift
    35x12.5 MTs
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just an FYI guys. I mean an offset pin location to move the axle back on the spring, it has nothing to do with the pinion angle.
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think we're all talking about doing both: offset, and angle. Keep in mind that moving the axle on the spring will change the angle a little, it's not much, but technically it's there.
    SW-ORD
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Have any of you guys looking for angles on your blocks tried calling a local machine shop to see what they'd charge you??
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  11. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    I called 3 places here in So. Ga. and they wanted $90 each to make me a set. Thanks to ORD they made me some at cosiderable savings.
    The Few, The Proud, The K5 Blazer
  12. jarheadk5
    Mar 6, 2000
    4,389
    PA
    NO NO NO, I'm talking about getting the angle cut on ORD's block, not getting your own blocks made! I'm not trying to steal Stephen's business here, just trying to help those of you who need pinion angle corrections with other ideas!
  13. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    We're looking at doing the angles in our shop, it's just figuring out what to do. We may just do them in 2,4 and 6 degree, and you can choose the closest one to what you need. We could do more too I guess. Much past that and you should probably move the perches.
    SW-ORD
  14. Mreetz
    Jun 26, 2001
    1,282
    Now that sounds like a good idea. Let me know what you decide.
    1984 K-5
    4" lift
    35x12.5 MTs
  15. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    forgive my ignorance but what would moving the axle do for you in the world of wheelin
    sun desert offroad http://community.webshots.com/user/scoobydann
  16. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    It moves the axle rearward because the shackle flip moves the axle forward a bit. This just centers the tire in the fenderwell, which could prevent the tires from rubbing so much.
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  17. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I dug up some old pics of my K5 with the 2.5" lift and 33 x 9.50's, kind of neat to see what it used to look like, it was really nice!
    Anyway, looking at the pic, the tire is a little forward in the rear wheel well. Maybe we should see if anyone has before and after measurements to see if the flip does move it forward. Just doing some geometry on it, I don't think it can move forward in the opening with a stock spring, but with a lift spring, it can.
    But regardless, there are a variety of reasons for moving it back, some of which may be important to some guys, some maybe not.
    Increased wheelbase
    decreased departure angle
    longer rear driveshaft
    more room in the opening for a larger tire without cutting
    SW-ORD
  18. ImpalaSS
    ImpalaSS 1/2 ton status
    Feb 1, 2001
    201
    ive seen some pictures of trucks with shackle flips and it looks like it does move it forward.....
    68 SWB 4x4 1 of 1,449 made 327, 465 4 speed, rockwell tcase, edelbrock performer intake+carb, MSD pro billet http://communities.msn.com/68K10
  19. ryanNC
    ryanNC 1/2 ton status
    Dec 7, 2000
    182
    North Carolina, Valdese
    One thing that has gone unmentioned is the centering holes in the ubolt plates on top of the springs will not line up anymore with an offset pin in the block? The centerline of the axle and spring isn't centered anymore from the shift of the axle backwards and the springs staying put.
    "need more <font color=green>cash</font color=green>"
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, you have to drill a new hole in the ubolt plate for it to work out. In the rear, you end up with a new hole, if you do it in the front, you just use a bit to dimple the plate enough to clear the bolt head. Not really a major operation.
    SW-ORD
