? on ONBOARD AIR
Discussion in 'The Garage' started by Chrisblazzer89, Nov 13, 2006.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    any simple and cheap onboard air systems out their for the expecting parent on a budget?
  2. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    I was told about this one at Harbor Freight. You get what you pay for so be careful when asking about "cheap".
    Use at own risk
    or
    I found this one for $10.00
    J/K
  3. Disturban
    Disturban 1/2 ton status
    Mar 9, 2006
    120
    Phx,Az
    Word of advice..Don't buy a VIAIR product.Mine never worked and still doesn't,they don't seem to want to do anything about it.
  4. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    I'm alittle leary about VIAIR products Heard nothing but bad
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Serpentine or v-belt? They can be done pretty cheap with a little ingenuity.
    My thoughts, junkyard York, make a few drawings and have the templates CNC plasma'd and welded together, bolt it up, run another v-belt, and find fittings from there.
  6. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    What was so bad about VIAIR? I've had it for a year and used it each time I wheeled. Aired down and aired back up my tires each time... I even used air tools several times...
    I guess it's just too soon to have mine come up with any problems.
  7. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    V belts
  8. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Pretty simple then, york, brackets, fittings, belt. ;)
  9. buefchris
    Dec 28, 2005
    1,503
    buena park ca.
    I'm not sure.I don't have a air compressor,but i've talked to some people and they all seemed to say its in the quality or lack there of.
  10. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
  11. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    what about the old school, ac pump??
  12. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    That's been mentioned with "York."
  13. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    The York works really well. If you can't cut your own brackets just buy them from Kilby Enterprises. They do some really neat receivers too plus you can get any fittings etc from them.
    If you use their bracket when you have a/c on a serp. set up you need to extend the PS resevoir neck, but I'm not sure about V belt set ups.
  14. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Here is how I did it.
  15. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  16. goldwing2000
    goldwing2000 Guest
    Kilby only sells brackets for serpentine belt systems.
    Muddytaz is the only person I've seen who sells brackets for v-belt setups.
  17. cbbr
    Jul 17, 2004
    14,681
    The ones that Muddytazz sells look great. Much better than the one that I made for my setup.
  18. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks guys, if anyone needs more info, just pm me :thumb:
  19. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I am thinking about doing this soon, I'm glad it came up.
    Great write up Chad:D
  20. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
    anyone used the original smog air pump bracket
    from the serp setup to mount a york compressor?
    it might fool the emission man too!
    just a thought.
