? on PS gear box fitting
Discussion in 'The Garage' started by 8_YOUR_H2, Oct 31, 2006.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I need to replace the low pressure return fitting on my PS gear box. The box is from an 85 chevrolet and uses the "o" ring. Can I use a piece of hardline for this? I found a piece of 3/8th with "O" ring that comes out into a 90 degree barb that would work great and I am getting it tonight.
  2. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    yep...
    I used the steel fitting from an 80's Olds Cutlass P/S box,when my steel line on the return side of the box rusted out--it was just a short length of tube, with the "O" ring fitting,and barbs on the other end..I used regular power steering return line hose to join it to the pump with hose clamps..:crazy:
