? on Spark plugs, distibutor cap/rotor
Discussion in 'The Garage' started by socal chevy, Jan 9, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    Just checked my plugs and they are pretty crusty. Need to replace them and the distributor cap/rotor. Where can I purchase these items? KRAGEN? and what brand would you all recommend?
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    any parts store should carry them, as to what brand, i think the general consensus is the ac delco plugs are best. dunno about the cap and rotor, maybe ac delco as well, i do know several that have an accel cap and rotor with good results, but i dont think its anything you would notice.
  3. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    Just get what ever cap/rotor yer local parts store has. Get delco plugs, unless you want to spend some $$ and get some platinum/iridium plugs.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    personally i'm a far of Borg-Warner tune up parts.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    any parts store, they all have those
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Just be advised that most parts store carry a "bargain" line and a "premium" line of ignition components. The extra few bucks for the premium stuff is money well-spent, IMHO.BTW, if you're gonna do the cap/rotor and the plugs, yoiu may as well throw a fresh set of wires on too.
  7. k5floyd
    Feb 6, 2004
    313
    Friendswood, Tx
    if you're getting wires, id recomend ac delcos, as they will fit perfectly and be correct legnth
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Thank you for all the help! :waytogo: :truck:
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    use good stuff
    I'd use AC plugs,Standard Ignition "Blue Streak" cap with brass inserts for the plug wires,and a name brand set of plug wires,avoid the cheap 20 dollar ones,they are junk right out of the box in many cases I've seen--I have bought AC Delco wires at a GM dealer for 25 bucks that are very good quality,and even have the cylinder numbers printed on them!(a nice feature to help install them,and identify which cylinder it is your dealing with)..I use wix filters on my trucks,or AC Delco,I think cheap oil filters are a waste of time and cash...
    I'd avoid any platinum plugs(Bosch seem to be the pits in my experience) and the "bargain brand" of caps and rotors..seen lots of them fail early--you get what you pay for most of the time!..:crazy:
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd Standard Ignition's Blue Streak.
    Autozone's, "PREMIUM" line of cap/rotors is the same as Carquest's cheapy line.
    Go for the good stuff!!!!!
    All blue streak stuff has a part number ending in "X"
