on the subject of oil...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JoshA, Sep 3, 2002.
  1. JoshA
    JoshA 1/2 ton status
    Apr 9, 2001
    104
    slc,ut
    I bought a set of gm chrome valve covers a few months ago, but I've got a problem when I want to add oil.
    there is a baffle (or something) below every hole in the valve covers, so it restricts the flow of oil into the engine, which means I have to pour it in veeeeeeeeeery slowwwwly.
    its a real pain in the ass. anybody got a solution?
    thanks.
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    heat up your oil.... Rebuild you engine so you don't need straight 60wt.
  3. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Trade with me ... I have a set of Mickey Thompson finned aluminum valve covers with no baffles and holes right over the rocker arms ... mine like to spit oil out the fill hole and into the PCV valve .. but dumping oil in is a snap
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    They make extension tubes for oil ports. I used one on my small block so that it was easier to pour it in. This might be an idea for you.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Use a bigger funnel that will hold a quart. Then drink a beer while you wait. Dump in another quart, slam another beer! What's the rush anyway?
    Good luck
  6. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I hate aftermarket valve covers because they don't have an oil filler hole. I cut up a stock valve cover and welded the bung to my aftermarket covers so that I could have a real oil filler.
    If you are not running roller rockers or poly-locks, I'd suggest going with a nice set of early LT-1 valve covers instead of the stamped steel chrome jobbies.
