onboard air suggestions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefjerky, Feb 12, 2002.
  1. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    i would like to install an onboard air system. i need a system for an arb, tire inflation and so on. ineed to know what to purchase and what not to purchase. thanks rob86k5
  2. BUDDY
    BUDDY 1/2 ton status
    Apr 28, 2000
    744
    Midland, TX
    Go here,
    <a target="_blank" href=http://www.onboardair.com/links/links.html>http://www.onboardair.com/links/links.html</a>
    HTH,
    Buddy
    72 K-5, 33x12.5's, 350/350/205,12-bR,d44F soon to be 39.5'x15.5s, EFI502/nv4500/doubler205, d60F, d70R. Stay tuned.
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    Or you could do this <a target="_blank" href=http://coloradok5.com/york.shtml>http://coloradok5.com/york.shtml</a>
    BIGJ
  4. hoserr
    hoserr Registered Member
    Jul 25, 2001
    78
    chula vista, ca
    i went the electrical way, Quickair. not the cheepest but definately easy. buy it, wire it, use it, i had the compressor kind but didn't want the weight, so i scraped it.the new way works good too. goes from 15lbs -25lbs in a few minutes. easy to mount also.
    uh, think it'll fit?
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is there an electric compressor that has the output to run air tools? If so what is it and what does it run?
    My Chevy isn't broken, its just out of gas.
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
  7. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    build-it-yourself CO2 tank? 8)
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  8. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i saw a twin 2.5 gal (5gal total) gas powed compressor for 99 at harbor freight. if you have the space, it could save you a hell of a trouble and time. just bring it along when you plan on going wheeling...
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Do you want AC compressor type or electrical pump?
    I will tell you about my electrical if you are interested in that option.
    Currently I am working on an inline regulator for my ARB so I can take advantage of my pumps 150psi potential.
    Dave
    Rehab is for quitters.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  10. beefjerky
    Feb 14, 2001
    64
    i just want to add a 2.5 gal tank with a couple of outlets. would the arb pump be up to the task of operating the tank(s) and the locker? any suggestions on tank(s) placement? thanks
  11. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I asked Arb that same question, if their compressor could handle filling up a small tank, etc. and they told me NO.
    Boss
    Pic of my truck Before N' After
    <a target="_blank" href=http://coloradok5.com/gallery/BeforeNAfter>http://coloradok5.com/gallery/BeforeNAfter</a>
  12. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    There are better compressors for less money anyway.
    They may take up more room under the hood tho - usually not a prob on K5s.....
    Dave
  13. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    In the late 70 chevy vans they had a york with brackets that mounts right to you motor and if you grind an inch or so off you can use the a/c too. real cheap getup watch the local yard and I will try to find the write up on this if you want. pm me.
    Chris
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
  14. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    the real question is whether or not you could use a CO2 tank to operate a ARB diff....
    J
  15. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I'm interested in this 70's van thing, if you have a write up or something send it my way would ya thanks.
    Like em big and topless
    You call THAT...a 4x4....LMAO?
  16. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Would appriciate it if you would send it my way too.
    Dawson
    Raleigh, NC
    88 K5, 6" lift, 36" TSL Radials, 14 Bolt, Rancho 9012s
  17. doonjumper
    doonjumper 1/2 ton status
    Mar 9, 2001
    948
    Visalia, California
    <font color=green>I went with extreme air. Puts out 145 psi. Comes with all hardware circuit breaker,wiring, and good instructions. Looks awsum too. It was kinda pricy but what the heck when it comes to my truck the sky's the limit. I just told my wife to work some extra overtime.</font color=green>[​IMG]
    [image]http://www.paceparts.com/images/smily1.gif[/image]
