Onboard Air Tank Size
Discussion in 'The Garage' started by Cricket, Jul 29, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I've searched through the onboard air archives. The one item that is not mentioned consistently is tank size and a convenient place to pick one up.
    The tech article uses a 2.5 gal tank at 150 max psi. What size/psi are you guys using and where did you find your tanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I have a 2.5 gallon tank i bought from sun-performance. I t gets the job done just fine if you are using a blow gub or impact gun for short durations. I am in the process of building a rear tube bumper which will be sealed and double as an air tank as well and i figure it will hold another 5 gallons or so. My current tank is mounted on the inside passenger frame rail about under the rear passenger seat foot area.
  3. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm running a 2 gallon tank, york 210. 95 psi on- 120 off. Too small IMO. The compressor cycles too much for my likeing. I don't have room for any higher capacity, so I deal with it. Put in the biggest volume you can safely fit somewhere. BTW, I made my own tank to fit inside the frame rail. My .02
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    how much does like a 2-3 gallon tank run??
  5. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Ebay, you can get polished stainless steel even :pimp:
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I run an 8 gallon tank on my York OBA system.
    I can run air tools and reseat tire beads fairly easy.
    Compressor still cycles- just not as often as other's systems.
    I used an $18 portable air tank from Home Depot.
    It comes with a gauge and a pop off valve as well.
    I have a 1" body lift which allowed me to mount it to the frame
    above my rear axle.
  8. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    whats the measure ments on that? that sounds like a good deal. :laugh:
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm running 2 tanks under my burb, 8 gallons each
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used an old compressor tank. 6 gals I think. Mounted it under the hood - drivers side. Just move the washer fluid res. forward. I run air tools with no problem off of the York.
  11. mudnmyvayne
    mudnmyvayne 1/2 ton status
    Jan 13, 2004
    173
    Texas Panhandle
    I snagged mine from the local Big-Rig wrecking yard. $10 IIRC
    They have many different sizes.
  12. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    We just changed over to a different self contained breathing apparatus in my FD. I'm going to try and get one of the old SCBA bottles and use it for a portable air tank. I think it holds roughly 80 cubic feet of air, at 4500 psi. That's a lot of air, but nothing like having the compressor & tank. More than likely I'll get a comp w/ tank, but will probably still carry the scba bottle as well.
    I almost got a bottle the other day, but the pile I looked through all had holes drilled in them to keep anyone from using them. :mad: There are still a butt load of good ones around, I just need to get my hands on one before they meet the same fate. The nice things is, they also have the backets for the old scba'a laying in a pile too.
    When I need to fill it up, I'll just take it by one of the stations that re-fills our bottles, and do it myself.
  13. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    5 gallon also from a big rig wreaking yard for $5. its about 15" long and 10" around (i think im trying to remember) it fit under the hood in front of the dr side fender sorta standing on end behind the headlight. i dont have it installed anymore since my compressor died.
    balzer
  14. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    Heres my setup. still finishing it off with some wiring, etc. Tank is 2.5 gal.
