Onboard Air using GM log style compressor.... how many don't run oilers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Oct 18, 2002.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Onboard Air using GM log style compressor.... how many don\'t run oilers?
    I scored a brand new GM log style compressor, its the long one. Full bracketry and flange. I'm going to use this for onboard air. I've got all the components lined out and I'm just looking to see how many of you run this type of compressor and do NOT run in-line oilers in front of it.
    Do you just add a few drops of oil before a planned run?
    If so, have you had any problems with the compressor after heavy use? Thanks in advance....
  2. Great78burb
    Great78burb Registered Member
    Sep 24, 2002
    28
    San Diego, CA
    Re: Onboard Air using GM log style compressor.... how many don\'t run oilers?
    I'm certainly no expert, but everyone I know that has used a compressor like that has sprayed a shot of pneumatic tool oil in the intake side just before using it. The same sort you would use on an impact gun. I know those type of compressors get their lubrication from the refrigerant, that's why most people like the York compressors for onboard air. They are self oiling with an internal reservoir. I have a York myself, I just haven't found the bracketry to hook it up yet. /forums/images/graemlins/burb.gif
  3. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    when u go to a york, is usually when the fabricating skills come in
    NITRO
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I used the oiler before and swithable de-oiler after. The compressor works great, way better than any ARB noisy thing...anyhow, I've never run it without the oiler, but from everything I've read, here and in magizines, it is not recommended. I remember an article in a mag a few years back that was doing it, but they just hooked it up and ran it, but did say if they planned on using it on the truck permenently, they would add the oiler.
    BlazerMan
  5. buefchris
    buefchris 1/2 ton status GMOTM Winner
    Dec 28, 2005
    1,503
    buena park ca.
    This thread has not been seen for some time now so I thought I'd revise it.
    Anyone who has the old log style compressors converted could you show me some picture as to how you did it, things to look for, oilers[if necessary].
    I finally decided to do away with the A/C and want to convert it.
  6. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
