Onboard air
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 27, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    I just came to a realization yesterday. I don't really NEED to convert an A/C compressor to use for air. I mean how often will I really NEED to use air tools on the trail. For no more than it happens, I can use a 4-way and socket set for trail repairs. So now I just need a compressor for airing up the tires and thats it. What about the QuickAir 2 electric one??? Anyone used this one? I just think an electric one would make for an easier, cleaner installation and take up alot less space.
    '73 K5
    Chevy good...Ford bad
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    May be cleaner, but which is cooler??? Nothin beats being to air up all 4 35's in under 5 minutes.. try that with a little electric one... Besides the option of helping others on the trail is nice too... with on board air the possibilities are endless...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  3. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    You make a really good point about the air tools, and I used to feel the same way. But, after experiencing how much faster and easier trail repairs go with air tools, I'm real glad I can run em'. Running a die grinder is a heck of a lot faster than using a hacksaw. You may never need air tools on the trail, but consider this: If your onboard air setup supplies enough air to run air tools, then that means it also fills tires quite a bit faster too. And, it could supply enough air to re-set a bead if you need it to. The quick air setup should work ok, but I would run a reserve tank with it instead of just the compressor. You could also run a Power Tank, or make one. That would be another option. Just a few things to think about.
    BIGJ
  4. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i would like to know how to change my ac pump over to an air compressor. do you got anything on how to do this?
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do a search on the topic. There were alot of posts obout this within the last month.
    '71 Blazer CST with alot of rust
  6. 454Blazer
    454Blazer Registered Member
    Nov 1, 2000
    23
    Albuquerque, New Mexico, USA
  7. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    <A target="_blank" HREF=http://home.europa.com/~bateman/jeep/78cj5/mods/air/schem.gif>http://home.europa.com/~bateman/jeep/78cj5/mods/air/schem.gif</A>
    For the extreme lazy
  8. 454Blazer
    Nov 1, 2000
    23
  9. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have a co2 tank that I can mount in my truck when I go wheelin.It holds 1200lbs of co2.It will air up tires run air tools and it lasts quite a while.Its a small tank,28" tall by 9" in diameter.
    All work and no play makes Frizz a dull boy.
