Onboard Air
Discussion in 'The Garage' started by Raven, Jun 20, 2002.
  1. Raven
    Raven Newbie
    Jun 18, 2002
    3
    Highlands Ranch, CO
    I am wanting to put onboard air on my 86 Jimmy. Does anyone have any suggestions or ideas?
    Raven
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Well as I see it you have 3 choices
    1. Co2 Tanks (PowerTank)
    2. Electric Pumps w/tanks(QuickAir)
    3. York A/C air compressor conversion w/tank (motor drivin)
    I choose #1, Portable & self contained. downfall is if the tank is empty your SOL.
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I am running a 5 gallon air tank "T"'ed into my Quick-air for my ARBs. Someday, this 5 gallon will have a ARB switch so I can use the 5 gallon when I want. Right now there is a manual valve on it.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used the york and its great. I found a conversion done on a work van in the junyard and snagged the brakets of off a chevy small block. It was a complete bolt on job.
  6. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    If you have the time and the patience to design and make some simple brackets, the York OBA it is a very cheap and effective alternative. I built the brackets for my 500 caddy, installed a air tank under the passenger side frame rail, and installed a hand throttle/wlock for running up the rpm's to 2500 for airtool use. I'm very pleased with it and only spent around $100 for the entire system.
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    BigBadCad,
    What type of hand throttle w/lock are you using? Where did you source it, cost, part #, etc.
    Thanks,
  8. MR.GADGET
    MR.GADGET Registered Member
    Jan 9, 2002
    33
    Raleigh NC
    I went with the twin power tanks (2-10 lb tanks) and with all the people telling me
    I'm SOL when I run out so I got a Quick Air 2 hard mount and in 1.5 years
    I have not run out and been left to use the Quick Air. I run air tools,
    welder (shielding gas for Ready Welder II), and fill tires.
    Jon
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have a 1000 watt invertor in my rig and a 110 volt CH tankless compressor. It airs up tires pretty quick and I have power for tools. It also makes me pretty popular after a hot trail ride, when I drop the tailgate and pull out the blender /forums/images/icons/wink.gif
  10. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    the hand throttle that I use for throttle control is a homebrew. It's a used=free mountainbike shifter bolted under my dash and it's not something I would use for daily driving....altough it gives me a chance to rest my foot on the wide open highways once and awhile.
  11. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    I used a york off of a bronco. i used the stick bronco mount and fabbed up all the other parts that i needed. easy as pie
    NITRO
  12. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Damn how much cash did you drop on onboard air? $800?? /forums/images/icons/ooo.gif
