Onboard Air!
Discussion in 'The Garage' started by OrangeCrushK10, Mar 9, 2004.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    It works! My onboard air system works! Mwa-ha-ha-ha-ha!
    /forums/images/graemlins/thumb.gif
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    And what kind of setup did you go with? /forums/images/graemlins/dunno.gif
  3. OrangeCrushK10
    Jan 25, 2003
    1,425
    York compressor from a volvo ($15). Basically it's the exact same as the set-up in the Tech section except without the unloader line and lot larger tank with a pressure gauge in the cab and no safety valve.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    no safety valve.
    /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
    Got any pics yet of your whole set-up?
  5. OrangeCrushK10
    Jan 25, 2003
    1,425
    Well, the york only gets up to 90psi and everything is either rated 150psi or 200psi, so I figured I was pretty safe.
    Oh, and I didn't order any parts from Onboardair.com (Kilby Ent). They never responded to my e-mails, so being the impatient person I am, I just did it myself for cheaper. Used the original york fittings, a gas RC car intake filter for the intake filter, and went down to AAI Racing and picked up a -08 AN (the original fitting size on the york) to 1/4" NPT adapter and a coupling.
    It works beautifully! I set the pressure valve to cut in at about 60psi and cut out at 90psi. Ran the die grinder all morning on it only having to take about 90sec breaks to let it catch up (Has a huge tank, so it takes a little bit). /forums/images/graemlins/woot.gif
    I'll see if I can get some pictures of it this weekend!
