Once again...700R4 oil pump seal replacement
Discussion in 'The Garage' started by 88K5Jimmy, Aug 1, 2006.
  1. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Do I have to replace the input seal and is there anything that can make the oil pump seal go bad? I have replaced it about a year ago and it is leaking again. What do you guys think? Also, what are the torque specs on the oil pump cover bolts?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Are you putting any locktite on the seal when you put it in?? They are know to back out after awhile and the locktite will keep them in.
  3. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I didn't replace the seal my self the last go around. So they may or may not have have put locktite on the bolts. They weren't backed out when I was looking under there, however I was able to tightne them a bit more, however, that didn't help the fact that it was still leaking.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Bushing in the pump could be worn, allowing a little wobble. Or the converter is screwed up a little.
  5. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    I guess I should mention what I have replaced:
    torque converter
    oil pump seal
    tranny pan and gasket
    tv cable gasket
    input seal
    This has all been in the past 1-1.5 yrs. I don't know if the bushing has been replaced or not, I just can't seem to understand how the oil pump seal is leaking again after such a short amount of time. It makes it look like the tranny gasket is leaking, so that was the last thing I replaced, NEW pan and gasket, this last week. I filled it back up with fluid and not even 20 minutes later there was a run of fluid going down the bellhousing cover. I was so furstrated that I didn't even get mad....
  6. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    I have the same thing happening to me, an i had the tranny rebuilt about a year ago too.
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I was talking about the actual seal. The seals are know to walk themselves out over time so a little locktite holds it in. This may or may not be your problem just something to look out for.
    When my bushing went out it POORED fluid, there wasnt any dripping to it.
  8. 88K5Jimmy
    Jan 10, 2001
    1,323
    Tulsa OK
    Thanks for the PM 85mudblazin. I also talked to my mechanic that only deals with GM stuff and I described the situation to him and what you guys had stated and he agreed about the bushing and the pump, etc. Do you have to pull the input seal to get the pump cover off and pump out?
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    There is no pump cover, you will need to pull the whole pump out and pull out a few bolts that hold the pump together. Once those are out the pump will split into 2 halfs and its in there.
    Only thing is that the pumps are usually a pita to get out unless you have a pump puller, so be careful if you try to pry it out.
  10. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    18 ft lbs. on the pump bolts. Use a criss cross pattern
