Once again, brighter headlights. Two system.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Nov 19, 2002.
  1. Ben Malinski
    Ben Malinski Guest
    I have searched this site on making my headlights brighter but the info is for a four headlight system. What about the 2 headlight system? Any ideas? Anyone done it? If so, diagrams please. Thanks!
  2. unsane
    unsane Guest
    how about a putting a four headlight system on your 84?
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's the same idea for a 2-lamp system. Install one relay on the low beam circuit and one on the high beam circuit. Power for the lights would then come directly from the battery, instead of being routed from the battery, through the connectors on the fuse block, through the circuit breaker, through the through the headlight switch, through the connector on the back of the headlight switch, back through the firewall and finally to the headlights. You can lose 1 to 3 volts through that maze as the connections age.
  4. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    switch to the 4 headlight system. I did on my 84 and love it got a couple pix if you like in my profile
